Updated on 2026-09-15 GMT+08:00
SFS Volume Overview
Introduction
CCE Autopilot allows you to mount a volume that is created from a Scalable File Service (SFS) file system to a container for persistent data storage. SFS volumes are commonly used in ReadWriteMany scenarios for large-capacity expansion and cost-sensitive services, such as media processing, content management, big data analysis, and workload analysis. For services with a massive number of small files, SFS Turbo file systems are recommended.
Not all regions support SFS volumes. View the regions where SFS volumes are supported on the console. Before using a general-purpose file system (SFS 3.0 Capacity-Oriented) for storage, ensure that a VPC endpoint for the cluster to access the file system has been created in the VPC where the cluster is running. For details, see Configuring a VPC Endpoint.
Expandable to petabytes, SFS provides fully-hosted shared file storage, highly available and stable to handle data- and bandwidth-intensive applications.
  • Standard file protocols: You can mount file systems as volumes to servers, the same as using local directories.
  • Data sharing: The same file system can be mounted to multiple servers, so that data can be shared.
  • Private network: Users can access data only in private networks of data centers.
  • Capacity and performance: The capacity of a single file system is high (PB level) and the performance is excellent (ms-level read/write I/O latency).
  • Use cases: Deployments and StatefulSets in the ReadWriteMany mode, and jobs created for high-performance computing (HPC), media processing, content management, web services, big data analysis, and workload process analysis
Performance
SFS provides two types of file systems: General Purpose File System (formerly SFS 3.0 Capacity-Oriented) and SFS Capacity-Oriented. CCE Autopilot clusters support only General Purpose File System (formerly SFS 3.0 Capacity-Oriented). For details about the performance of General Purpose File System, see File System Types.
Table 1 Performance
Maximum bandwidth
1.25 TB/s
Maximum IOPS
Million
Latency
10 ms
Maximum capacity
EB
Application Scenarios
SFS supports the following mounting modes based on application scenarios:
  • Creating an SFS Volume Statically: static provisioning. You use an existing file system to create a PV and then mount the PV to the workload through a PVC. This mode applies to scenarios where the underlying storage is available or billed on a yearly/monthly basis.
  • Creating an SFS Volume Dynamically: dynamic provisioning. You do not need to create volumes in advance. Instead, you need to specify a StorageClass during PVC creation. A file system and a PV will be automatically created. This mode applies to scenarios where no underlying storage is available.
Billing
