New Pods
Check Items
Check whether pods can be created after a cluster is upgraded.
Create pods and ensure the new and existing pods provide the same services.
- In the navigation pane, choose Workloads. On the displayed page, click Create Workload or Create from YAML in the upper right corner. For details about how to create a workload, see Creating a Workload.
Figure 1 Creating a workload
It is a good practice to use the image for routine tests as the base image. You can deploy minimum pods for an application by referring to the following YAML file.
apiVersion: apps/v1 kind: Deployment metadata: name: post-upgrade-check namespace: default spec: selector: matchLabels: app: post-upgrade-check version: v1 template: metadata: labels: app: post-upgrade-check version: v1 spec: containers: - name: container-1 image: nginx:perl imagePullPolicy: IfNotPresent resources: requests: cpu: 10m memory: 10Mi limits: cpu: 100m memory: 50Mi - After the workload is created, check whether the pods of the workload are running normally.
- In the navigation pane, choose Workloads. On the displayed page, locate the post-upgrade-check workload and choose More > Delete in the Operation column to delete it.
Solution
If pods cannot be created or are abnormal, submit a service ticket.
