Services
Check Items
After a cluster is upgraded, check whether its services are running properly.
Different services have different verification mode. Select a suitable one and verify the service before and after the upgrade.
You can verify the service from the following aspects:
- The service page is available.
 - No alarm or event is generated on the normal platform.
 - No error log is generated for key processes.
 - The API dialing test is normal.
Solution
If your online services malfunction after the cluster upgrade, contact technical support.
