Cluster Status
Check Items
After a cluster is upgraded, check whether the cluster is in the Running state.
CCE automatically checks your cluster status. Go to the cluster list page and confirm the cluster status based on the diagnosis result.
Solution
If your cluster malfunctions, contact technical support.
