Kubernetes Metrics Server
Kubernetes provides resource usage metrics, such as container CPU usage and memory usage, through the Metrics API. These metrics can be directly accessed by users (by running the kubectl top command) or used by a controller in the cluster (for example, HPA) to make decisions.
Kubernetes Metrics Server is an aggregator for monitoring data of core cluster resources. You can quickly install this add-on on the CCE console.
After this add-on is installed, you can create HPA policies. For details, see HPA Policies.
The official community project and documentation are available at https://github.com/kubernetes-sigs/metrics-server.
Editing the Add-on
- Log in to the CCE console, click the cluster name to access the cluster console, choose Add-ons in the navigation pane, find the Kubernetes Metrics Server add-on on the right, and click Edit.
- On the Edit Add-on page, modify the specifications.
Table 1 Kubernetes Metrics Server specifications Parameter
Pods
Number of pods for the add-on.
CPU and memory quotas of the containers for running the add-on.
- Click OK.
Components
Component |
Description |
Resource Type |
metrics-server |
Aggregator for the monitored data of cluster core resources, which is used to collect and aggregate resource usage metrics obtained through the Metrics API in the cluster |
Deployment |
