Help Center/ Cloud Backup and Recovery/ User Guide/ Vault Management/ Associating Resources to a Vault
Updated on 2025-01-17 GMT+08:00
If you have already associated servers, file systems, or disks when purchasing a vault, skip this step. If you need to enable automatic association, see Automatic Association.
After a server backup vault, SFS Turbo backup vault, or disk backup vault is created, you can associate servers, file systems, or disks with the vault to back up these resources.
After a hybrid cloud backup vault is created, servers and disks cannot be associated with the vault, but you can synchronize backups of on-premises servers and storage systems to the cloud. For details, see Hybrid Cloud Backup.
New resources cannot be associated with vaults in AZ2 of the CN North-Beijing1 region to perform backups. Resources already associated are not affected, and backups can still be performed.
  • A vault can be associated with a maximum of 256 resources.
  • The servers you plan to associate with a vault must have at least one disk attached.
  • The vault and the resources you plan to associate with it must be in the same region.
  • The total size of the resources to be associated cannot be greater than the vault capacity.
  • Resources can be associated only when they are in the statuses in the table below.
    Table 1 Resource statuses available for association
    Resource Type
    Status
    Cloud server
    Running or Stopped
    Cloud disk
    Available or In-use
    SFS Turbo file system
    Available
  1. Log in to the CBR console.
    2. Click in the upper left corner and select a region.
    3. Click and choose Storage > Cloud Backup and Recovery. Select a backup type from the left navigation pane.
  2. On a backup page, locate the target vault and click Associate Server/Associate Disk/Associate File System.
  3. In the resource list, select the resources you want to associate with the vault. After resources are selected, they are added to the list of selected resources. See Figure 1.
    Figure 1 Associating servers
    If you only want to associate some disks of an ECS, click the drop-down arrow on the left of the ECS name and select the disks you desire.
  4. Click OK. In the vault list, you can view the number of associated servers/disks/file systems in the Associated Servers/Associated Disks/Associated File Systems column.
    If a new disk is attached to an associated server, CBR automatically identifies the new disk and includes the new disk in subsequent backup tasks.
If you enable automatic association for a backup vault, the vault will automatically associate the unprotected resources and back them up according to the backup policy applied to the vault.
  • The vault's remaining capacity should be greater than both 40 GB and the associated capacity. The vault will automatically scan and associate unprotected servers in the next backup cycle and perform backup. Remaining capacity of a vault = Total capacity of the vault - Capacity of resources associated with the vault. You can obtain the vault's total capacity and associated capacity in the Basic Information area on the details page of the vault. For example, if you have an 800-GB server backup vault and it has been associated with two 100-GB servers, its remaining capacity is 600 GB (800 GB – 200 GB). In this case, the vault will automatically associate unprotected servers in the next backup cycle and perform backup.
  • If multiple vaults are enabled with automatic association, CBR scans their backup policies and associates resources with the vault whose next scheduled backup time is the earliest.
  • If the capacity of the first selected vault is used up, resources will be associated with the vault whose next scheduled backup time is the second earliest.
  • If a backup policy with the earliest scheduled backup time is applied to more than one vault, CBR randomly associates the resources with one of these vaults.
  • If a vault has automatic association enabled but has no backup policy applied, no resources will be automatically associated with this vault. You can manually associate unprotected resources.
  • After automatic association is disabled for a vault, the vault stops automatically scanning for unprotected resources. Associated resources are not affected.
    3. Choose Storage > Cloud Backup and Recovery.
  2. On any backup page, locate the target vault.
  3. Choose More > Enable Automatic Association in the Operation column of the vault.
    You can filter unprotected resources by tag. If a tag is selected, only unprotected resources with the specified tag will be associated with the vault. Or, all unprotected resources will be associated.
    If no tag is available, you can create tags on the corresponding resource page. You can search for vaults by specifying a maximum of 5 tags at a time. If you select more than one tag, the vaults with any of the specified tags will be returned.
    Figure 2 Enabling automatic association
  4. Check that Automatic association is displayed in the Associated Servers column of the vault list.
  5. (Optional) If automatic association is not required, choose More > Disable Automatic Association in the Operation column of the vault. See Figure 3.
    Figure 3 Disabling automatic association
