Help Center/ Cloud Backup and Recovery/ User Guide/ File Backup (Supported Conditionally)/ Uninstalling the Agent
Updated on 2026-01-22 GMT+08:00
Uninstall the agent from a backup client if file backup is no longer needed.
Uninstalling the Agent from Linux
- Log in to the server whose Agent needs to be uninstalled and run su - root to switch to user root.
- In the /opt/huaweicloud/cbragent/bin directory, run the following command to uninstall the Agent. If information similar to Figure 1 is displayed, the Agent has been uninstalled.
sh agent_uninstall.sh
Uninstalling the Agent from Windows
- Log in to the server whose Agent needs to be uninstalled.
- Go to the bin directory in the installation path and double-click agent_uninstall.bat. Enter y to uninstall the Agent.
If information similar to Figure 2 is displayed, the Agent has been uninstalled.
Parent topic: File Backup (Supported Conditionally)
