Updated on 2025-08-05 GMT+08:00
Creating a Replication Policy
If your enterprise needs to expand services across regions or comply with regional regulations, you can use cross-region replication to replicate data to a specified region.
A replication policy allows CBR to periodically replicate backups that have not been replicated or failed to be replicated to the destination region. Replication policies enable you to replicate backups across regions at a specified interval, ensuring service continuity and precise management and use of backups in the destination regions.
When both a backup time and a replication time are configured, ensure that replication starts after backup is complete. Or, replication may fail.
  • You can only apply replication policies to server backup vaults, SFS Turbo backup vaults, and hybrid cloud backup vaults.
  • A maximum of 32 replication policies can be created in each account.
  1. Log in to the CBR console.
    2. Click in the upper left corner and select a region.
    3. Click and choose Storage > Cloud Backup and Recovery.
  2. Choose Policies in the navigation pane and click the Replication Policies tab. In the upper right corner, click Create Policy. Select Replication Policy for Type.
    Figure 1 Creating a replication policy
  3. Set the replication policy parameters. Table 1 describes the parameters.
    Table 1 Replication policy parameters
    Example Value
    Type
    Select a policy type. In this section, we select the replication policy.
    Replication policy
    Name
    Replication policy name You can enter a custom name or use the default name policy_xxxx.
    A name must contain 1 to 64 characters including digits, letters, underscores (_), or hyphens (-).
    replication_policy
    Status
    Whether to enable the replication policy By default, this function is enabled.
    CBR replicates backups and deletes expired replicas only after a replication policy is enabled and applied to vaults.
    Enabled
    Replication Frequency
    Select a replication frequency. By default, the replication task is executed automatically every Monday, Tuesday, Wednesday, Thursday, Friday, Saturday, and Sunday.
    • Weekly
      Specifies on which days of each week the replication task will be executed. You can select multiple days.
    • Day-based
      Specifies the interval (every 1 to 30 days) for executing the replication task.
    If you select day-based replication, the first replication is supposed to be executed on the day when the replication policy is created. If the replication policy is created after the replication time, the first replication will be executed in the next replication period.
    Every day
    Execution Time
    Execution times of the replication policy in a day The default replication time is 22:00.
    Replication tasks can be scheduled at the beginning of each hour, and you can select multiple hours.
    You can select multiple times, either on or off the hour, for replication. If you select a time that is not on the hour, you can customize the time (0 to 59 minutes). For example, you can select a time that is not on the hour, such as 00:10 and 01:10.
    It is recommended that replication be performed during off-peak hours or when no services are running.
    00:00, 02:00
    Retention Rule
    Rule that specifies how backup replicas will be retained in the destination region By default, backup replicas are retained for one month.
    • Backup quantity
      You can set the maximum number of backup replicas to retain for each resource. The value ranges from 2 to 99999.
      You can also set long-term retention rules with advanced options. Long-term retention rules and quantity-based retention rules will be both applied.
      • Day-based: 0–100
      • Weekly: 0–100
      • Monthly: 0–100
      • Yearly: 0–100
      A resource may be replicated multiple times in a day. If day-based replication is configured, only the most recent backup replica of that day is retained. If you set Day-based to 5, the most recent backup replica of each of the last five days that have backup replicas generated will be retained and the earliest backup replicas will be deleted automatically. If day-based, weekly, monthly, and yearly retention rules are all configured, all the rules will apply and the union set of backup replicas will be retained. For example, if Day-based is set to 5 and Weekly to 1, five backup replicas will be retained. The long-term retention rule and the quantity-based retention rule both apply.
    • Time period
      You can choose to retain backup replicas for one month, three months, six months, one year, or for any desired number (2 to 99999) of days.
    • Permanent
      • The system automatically deletes the earliest and expired backup replicas every other day to avoid exceeding the maximum number of backup replicas to retain or retaining any backup replica longer than the maximum retention period.
      • There will be delays for CBR to delete expired backup replicas, but normally these delays will not be over 24 hours.
      • The retention rules apply only to auto-generated backup replicas, but not manual ones. Manual backup replicas need to be deleted manually.
      • After a backup replica is used to create an image, the replica will not be deleted by the retention rule.
    6 months
    Destination Region
    Region to which backups are replicated
    Only the regions that support replication will be displayed. For details about the supported regions, see Table 1.
    • If the selected region contains only one project, you can directly select the region name.
    • If the selected region has multiple projects, the default project of the region is preselected. You can select another project if needed.
    AP-Bangkok
  4. Click Create Now. After the replication policy is created, you can view it in the replication policy list.
  5. Locate the desired vault and choose More > Apply Replication Policy to apply the replication policy to the vault. Then you can view the applied policy on the vault details page.
    After the policy is applied, backups will be periodically replicated to the destination vault based on the policy.
Example
A user applies a replication policy to a vault in a given region at 11:00 a.m. on Thursday. According to this policy, backups will be replicated to the destination region on 02:00 a.m. every day, and only two backup replicas will be retained. According to this vault's backup policy, two backups are automatically generated at 00:00 every day. At 12:00 p.m. on Saturday, the replication vault will contain two backup replicas, which are replicated on Saturday. Backup replicas generated at 02:00 a.m. on Friday have been automatically deleted according to the replication policy.
