Configuring VPC to Access the CAE Environment
After adding the configuration for VPC to access the CAE environment, you can access the CAE application through the VPC network.
Adding the Configuration for VPC to Access the CAE Environment
To use this function, you need to use an account with the Security Administrator permissions to access CAE and click Authorize. Existing functions are not affected if you do not perform authorization.
- Log in to CAE.
- Choose System Settings.
- Click Edit in the System Network Configuration module.
- Click Add Configuration in the Connectivity Between CAE and VPC area.
- Select a subnet from the drop-down list and click OK.
- VPC is fixed to the VPC associated with the environment during environment creation, and set Subnet to the subnet to which the environment belongs.
- Currently, only one configuration can be added.
Figure 1 Configuring VPC to access the CAE environment
Deleting the Configuration for VPC to Access the CAE Environment
- Log in to CAE.
- Select the target configuration and click Delete in the Operation column.
- In the displayed dialog box, enter SWITCHOFF and click OK.
