Updated on 2025-07-10 GMT+08:00
Creating an Environment
You can create application components in different environments to isolate them.
By default, only one environment can be created under an account. Submit a service ticket to increase the quota.
A CAE runs on a VPC. Before creating an environment, ensure that VPCs and subnets are available.
You have created a VPC. For details, see Creating a VPC and Subnet.
If the engine is created using an account with the minimum permission for creating engines, for example, cae:environment:create in fine-grained permission dependencies of CAE, the default VPC security group cae-default-sg needs to be preset by the primary account and the rules listed in Table 1 cae-default-sg rules need to be added.
You have added a security group rule. For details, see Adding a Security Group Rule.
Direction
Priority
Policy
Protocol and Port
Type
Source Address
Inbound
Allow
TCP: 3000–65535
IPv4
0.0.0.0/0
Allow
All
IPv6
cae-default-sg
Allow
All
IPv4
cae-default-sg
Outbound
100
Allow
All
IPv4
0.0.0.0/0
100
Allow
All
IPv6
::/0
Do not modify or delete the default security group. Otherwise, the system may run abnormally.
An environment is used to isolate components you create. You can name an environment to automatically create a basic resource group for the current tenant.
  1. Log in to CAE.
  2. Use either of the following methods to create an environment:
    • If you use CAE for the first time, a message is displayed indicating that no environment has been created.
      1. Click Create Now in the Create Environment card.
        Figure 1 Creating an environment
      2. In the displayed dialog box, set the parameters by referring to Table 2.
        Table 2 Creating an environment
        Environment
        Enter an environment name.
        Enterprise Project
        Select an enterprise project.
        An enterprise project facilitates project-level management and grouping of cloud resources and users. The default project is default.
        It is available after the enterprise project function is enabled.
        Select the VPC to which the environment resource belongs from the drop-down list.
        To create a VPC, click Create VPC. For details, see Creating a VPC.
        The VPC cannot be modified after the environment is created.
        Subnet
        Select a subnet from the drop-down list.
        If no subnet is available, click Create Subnet to access the network console and create a subnet. For details, see Creating a Subnet for the VPC.
        Keep at least two available network IP addresses for CAE configuration and optimization.
        Security Group
        You can select Auto generate or Use existing.
        This group must allow access from the selected subnet to both the subnet gateway address and the access addresses and ports of middleware such as RDS and CSE instances.
        Organization
        If you use CAE for the first time, select Create Organization from the drop-down list and enter an organization name.
    • If this is not your first time using CAE, choose Components.
      1. Click next to Environment in the upper part of the page.
      2. In the displayed Create Environment dialog box, enter an environment name.
  3. Click OK.
