Updated on 2026-01-13 GMT+08:00
Deleting Tags
If you no longer need a tag, delete it in either of the following ways:
- Log in to the BMS console.
- In the BMS list, click the name of the target BMS.
- Click the Tags tab. Locate the row containing the tag to be deleted and click Delete in the Operation column. In the Delete Tag dialog box, click Yes.
Parent topic: Tag Management
