Searching for Resources by Tag
After tags are added to resources, you can search for resources by tag using either of the following methods.
Filter Resources in the Resource List
On the BMS console, query BMSs by tag key and value.
- Under Computing, click Bare Metal Server.
The BMS console is displayed.
- Click Search by Tag above the upper right corner of the BMS list to expand the search area.
- Enter the tag of the target BMS.
Both the tag key and value are mandatory. If the tag key or value is matched, the system automatically displays the target BMSs.
- Click
to add multiple tags.
You can add multiple tags. The system will display BMSs that have all the tags.
- Click Search.
The system searches for BMSs based on the specified tag keys and values.
Filter Resources on the TMS Console
- In the upper right corner of the page, click the username and select Tag Management from the drop-down list.
- On the Resource Tags page, set the search criteria, including Region, Resource Type, and Resource Tag.
- Click Search.
All the resources that meet the search criteria will be displayed in the Search Result area.
Provide feedbackFor any further questions, feel free to contact us through the chatbot.
