Configuring Event Alarm Rules
Event monitoring provides event data reporting, query, and alarm reporting. When there are specified events, you will receive alarm notifications and learn about the running status of your resources. You can set alarm rules for system and custom events. When a specified event occurs, Cloud Eye automatically sends an alarm notification. This helps you quickly identify and address issues.
- Log in to the Cloud Eye console.
- In the navigation pane on the left, choose Event Monitoring.
- In the upper right corner, click Create Alarm Rule.
To create an alarm rule for a specific event, locate the event in the event list and click Create Alarm Rule in the Operation column. On the Create Alarm Rule page, the required parameters are configured automatically for that event.
- On the Create Alarm Rule page, configure basic information about the alarm rule.
Table 1 Basic parameters Parameter
Name
Name of the alarm rule. The system already generates a random name. You can modify it. The rule name cannot exceed 128 characters. Only letters, digits, underscores (_), and hyphens (-) are allowed.
(Optional) Alarm rule description. A maximum of 256 characters are allowed.
- Select an object to be monitored and configure alarm parameters.
Figure 1 Configuring parameters
Table 2 Parameters of creating an alarm rule for event monitoring Parameter
Alarm Type
Alarm type that the alarm rule applies to. The default value is Event.
Event Type
Event type, which can be System event or Custom event.
Event Source
Name of the cloud service that triggers the event.
For a custom event, set Event Source to the value of event_source.
Monitoring Scope
Monitoring scope the alarm rule applies to. You can select Resource groups, All resources, or Specific resources.
If Event Type is set to System event, you can configure the monitoring scope. Currently, Resource groups is only available for DDS, RDS, and DCS event alarms.
Method
Method used to create an alarm rule. If you select System event for Event Type, Method can be Associate template or Configure manually. If you select Custom event for Event Type, only Configure manually is available.
- Configure manually: You can create a custom alarm rule as needed.
- Associate template: If you need to configure the same alarm rule for multiple groups of resources under the same cloud product, you can use a template to avoid repeated configurations.
Template
If Method is set to Associate template, you need to select a template.
You can select a default or custom template.
Event Name
A phrase that briefly describes an instantaneous operation triggering an alarm, such as login and logout.
For a custom event, the event name is the value of event_name when the custom event is reported.
Alarm Policy
Policy for triggering an alarm.
Alarm Severity
Alarm severity. Valid values are Critical, Major, Minor, and Warning.
Operation
You can click Delete to delete the alarm rule.
- Configure alarm notifications.
Figure 2 Configuring the alarm notification
Table 3 Parameters for configuring alarm notifications Parameter
Alarm Notifications
Whether to send alarm notifications by SMS, email, FunctionGraph (function), FunctionGraph (workflow), WeCom, DingTalk, Lark, WeLink, HTTP, or HTTPS. This parameter is enabled by default.
Notified By
Notification method. You can select Notification groups or Topic subscriptions.
- Notification groups: A notification group includes one or more notification channels to send notifications to specified recipients. For details, see Creating a Recipient and Notification Group.
- Topic subscriptions: You need to select recipients for alarm notifications. You can select either the account contact or a custom topic created in SMN.
Notification Group
Notification group that alarm notifications will be sent to. For details about how to create a notification group, see Creating a Recipient and Notification Group.
Recipient
Target recipient of alarm notifications. You can select the account contact or a topic. This parameter is available only if Notified By is set to Topic subscriptions. If there is a display name of a topic, the format is Topic name (Display name), and you can search for a topic by name or display name. If no display name is set for a topic, only the topic name will be displayed.
- The account contact is the mobile phone number and email address of the registered account.
- A topic is used to publish messages and subscribe to notifications. If the required topic is unavailable, create one first and add subscriptions to it.
For details, see Creating a Topic and Adding Subscriptions.
Notification Window
Cloud Eye sends notifications only within the notification window specified in the alarm rule.
If the notification window is set to 08:00-20:00, notifications are sent only within this specified time range.
Time Zone
Time zone for the alarm notification window. By default, it matches the time zone of the client, but can be manually configured.
Trigger Condition
When the alarm type is Event, you can select Generated alarm for Trigger Condition.
- Configure advanced settings.
Figure 3 Advanced settings
Table 4 Parameters for advanced settings Parameter
Enterprise Project
Enterprise project that the alarm rule belongs to. Only users with the enterprise project permissions can manage the alarm rule. To create an enterprise project, see Creating an Enterprise Project.
Tag
Key-value pairs that you can use to easily categorize and search for cloud resources. You are advised to create predefined tags in TMS. For details, see Creating Predefined Tags.
If your organization has configured tag policies for Cloud Eye, add tags to alarm rules based on the tag policies. If you do not follow the policies, alarm rules may fail to be created. Contact your organization administrator to learn more about tag policies.
- A key can contain a maximum of 128 characters, and a value can contain a maximum of 225 characters.
- A maximum of 20 tags can be created.
- Click Create.
You can go to the Alarm Rules page to check the alarm rule you created and filter the new alarm rule by its name.
