- What's New
- Function Overview
- Billing
- Getting Started
User Guide
- Enhanced Hyperledger Fabric BCS Management
- Best Practices
Developer Guide
- Overview
- Chaincode Development
- Application Development
- Demos
Blockchain Middleware APIs
- Overview
- Chaincode Invoking (OBT)
Chaincode Management
- Obtaining a Token
- Installing a Chaincode
- Instantiating a Chaincode
- Listing Installed Chaincodes
- Querying Version of a Specified Chaincode
- Querying Chaincode Installation Information
- Querying Chaincode Instantiation Information
- Querying an Appchain
- Listing Blocks
- Listing Transactions
- Querying Transaction Quantity
- Listing Block Transactions
- Querying Transaction Details
- Querying Peers
- Querying diskUsage of a Node
- Querying the System-Hosted Certificate Status
- Deleting a Chaincode
- Downloading a Report
- Distributed Identity (OBT)
- Trusted Data Exchange (OBT)
- Appendix
API Reference
- Before You Start
- API Overview
- Examples
- Calling APIs
APIs (Enhanced Hyperledger Fabric)
BCS Management
- Creating a BCS Service
- Querying Creation Status of a BCS Service
- Querying a BCS Service
- Modifying a BCS Service
- Creating Channels
- Querying Channel Information
- Adding Peers to a Channel
- Removing Organizations from a Channel
- Downloading Certificates
- Downloading the SDK Configuration
- Generating a User Certificate
- Unfreezing a User Certificate
- Freezing a User Certificate
- Querying Quotas
- Querying Flavors
- Querying Peer Information
- Querying Asynchronous Operation Results
- Querying the BCS Service List
- Deleting a BCS Service
- Removing a Peer from a Channel
- Deleting a Channel
- BCS Consortium
- BCS Monitoring
BCS Management
- Appendix
- Change History
- SDK Reference
- Billing
Instance Management
Consultation
- How Do I Determine Whether a Blockchain Is Necessary?
- What Underlying Framework Is Used for Huawei Cloud BCS?
- Can BCS Instances Deployed on the Public Cloud Access Blockchain Nodes on Other Clouds?
- What Competitive Advantages Does Huawei Cloud BCS Have?
- In Which Direction and What Capabilities Will Huawei Cloud BCS Develop?
- What Are the Specifications of VMs to Be Purchased for BCS?
- How Do I Get Access to the Partners of Huawei Cloud BCS for More Services?
- What Are the Differences Between Channel Isolation and Privacy Protection?
- How Well Does BCS Perform?
- Does BCS Support Customized Development?
- When Do I Need to Hibernate or Wake an Instance?
Service Usage
- Which Ports of a Security Group Are Opened When I Create a BCS Instance?
- How Do I Check Whether the ICAgent Is Installed for the Cluster?
- What Can I Do If I Can't Open the Blockchain Management Console?
- What Should I Do If My BCS Instance Remains in the Creating State?
- What Should I Do If a Peer Restarts Frequently with the Error Message "PanicDB not exist"?
- What Can I Do If the CPU Usage of a Blockchain Node Reaches 100%?
- Why Can't I Log In to the Blockchain Management Console?
- BCS.4009100: System Error
- How Can I Obtain Private Keys and Certificates for Enhanced Hyperledger Fabric Blockchains?
- Why Does Chaincode Instantiation Fail When I Deploy a Fabric v1.4 Instance Using a v1.19 CCE Cluster?
- Can All Blocks Be Saved As More and More Blocks Are Created?
What Can I Do If I Fail to Purchase a BCS Instance?
- General Checks
Detailed Checks
- CCE Cluster Quota Used Up
- Failed to Create a Cluster
- Failed to Create a PVC
- Cluster Already In Use
- SFS Turbo File System Quota Exceeded
- No EIP Bound
- CCE Is Abnormal
- Cluster Status Is Abnormal
- Subnet Unavailable
- Quick Deployment in Progress
- CCE Status Check Times Out
- Insufficient Master Nodes in the AZ of the CCE Cluster
Abnormal Instance Statuses
- What Can I Do If a BCS Instance Is in the Abnormal State?
- What Can I Do If a BCS Instance Is in the Unknown State?
- What Can I Do If a BCS Instance Is in the EIP abnormal State?
- What Can I Do If a BCS Instance Is in the Frozen or Cluster frozen State?
- What Can I Do If the BCS Instance and the peer-xxx StatefulSet Are Abnormal After an Organization or a Peer Is Added?
- Other Issues
Consultation
- Chaincode Management
- Data Storage to the Blockchain
- Demos and APIs
- O&M and Monitoring
- Consortium Management
- Videos
More Documents
- Managing Enhanced Hyperledger Fabric Instances
BCS FAQs
Instance Management
Consultation
- What Underlying Framework Is Used for BCS?
- What Competitive Advantages Does BCS Have?
- What Are the Specifications of VMs to Be Created for BCS?
Service Usage
- Abnormal Instance Statuses
- Other Issues
Consultation
- Demos and APIs
Instance Management
BCS FAQs
- Change History
- Developer Guide (ME-Abu Dhabi Region)
Downloading SDK Configurations and Certificates
BCS supports chaincode functions such as execution and query. Before developing an application, download the certificates and SDK configuration. The SDKs can use the configuration file to easily access the blockchain network and complete transactions. You do not need to manually configure the SDKs.
Before downloading the SDK configuration, ensure that the chaincode has been installed and instantiated.
The SDK configuration, certificates, and application must be used together. The SDK configuration file contains chaincode and certificate path information. Specify the chaincode name and the storage path of the downloaded certificate on the application executor when downloading the SDK configurations. If the certificate path changes, you must manually change all certificate paths in the SDK configuration file.
BCS supports three types of certificates: administrator certificate, user certificate, and CA certificate. The administrator certificate is required to create, join, and update a channel, and install, instantiate, update, and delete a chaincode. For transactions and query, you are advised to use the user certificate. Download the certificates on the Instance Management page.
- An administrator certificate contains the organization's administrator permission certificate and private key and can be used to manage channels and contracts.
- A user certificate contains the organization's user permission certificate and private key and can be used for transactions and queries.
- A CA certificate is the root certificate of an organization. The CA public and private key pair can be used to issue lower-level certificates.
- The administrator certificate differs between an orderer and a peer. For management within a channel, use the administrator certificate for peers instead of that for orderers.
- Encrypt the private keys in the downloaded certificates for storage.
- Log in to the BCS console.
- In the navigation pane on the left, click Instance Management.
- Click Download Client Configuration on an instance card.
- Select configuration files to download.
- SDK Configuration File: Specify the member, chaincode name, certificate path as required.
Table 1 SDK file parameters Parameter
Chaincode Name
Set it as required. The chaincode name must be the same as the name specified during chaincode installation and instantiation.
Certificate Path
Final path for storing the certificate for application compilation. If the certificate path changes, you must manually change all certificate paths in the SDK configuration file.
Channel
Select a channel.
Member
Select peer organizations in the channel.
- An orderer certificate is used for interacting with the blockchain system. Encrypt the private keys in the downloaded certificates for storage.
- A peer certificate is used for performing management operations within a channel. Encrypt the private keys in the downloaded certificates for storage. Select a peer organization and the certificates to be downloaded.
- Click Download. Decompress the SDK and store the retrieved .yaml file. Decompress the downloaded certificate packages and store the files in an application directory for the application to access.
