- What's New
- Function Overview
- Billing
- Getting Started
User Guide
- Enhanced Hyperledger Fabric BCS Management
- Best Practices
Developer Guide
- Overview
- Chaincode Development
- Application Development
- Demos
Blockchain Middleware APIs
- Overview
- Chaincode Invoking (OBT)
Chaincode Management
- Obtaining a Token
- Installing a Chaincode
- Instantiating a Chaincode
- Listing Installed Chaincodes
- Querying Version of a Specified Chaincode
- Querying Chaincode Installation Information
- Querying Chaincode Instantiation Information
- Querying an Appchain
- Listing Blocks
- Listing Transactions
- Querying Transaction Quantity
- Listing Block Transactions
- Querying Transaction Details
- Querying Peers
- Querying diskUsage of a Node
- Querying the System-Hosted Certificate Status
- Deleting a Chaincode
- Downloading a Report
- Distributed Identity (OBT)
- Trusted Data Exchange (OBT)
- Appendix
API Reference
- Before You Start
- API Overview
- Examples
- Calling APIs
APIs (Enhanced Hyperledger Fabric)
BCS Management
- Creating a BCS Service
- Querying Creation Status of a BCS Service
- Querying a BCS Service
- Modifying a BCS Service
- Creating Channels
- Querying Channel Information
- Adding Peers to a Channel
- Removing Organizations from a Channel
- Downloading Certificates
- Downloading the SDK Configuration
- Generating a User Certificate
- Unfreezing a User Certificate
- Freezing a User Certificate
- Querying Quotas
- Querying Flavors
- Querying Peer Information
- Querying Asynchronous Operation Results
- Querying the BCS Service List
- Deleting a BCS Service
- Removing a Peer from a Channel
- Deleting a Channel
- BCS Consortium
- BCS Monitoring
BCS Management
- Appendix
- Change History
- SDK Reference
- Billing
Instance Management
Consultation
- How Do I Determine Whether a Blockchain Is Necessary?
- What Underlying Framework Is Used for Huawei Cloud BCS?
- Can BCS Instances Deployed on the Public Cloud Access Blockchain Nodes on Other Clouds?
- What Competitive Advantages Does Huawei Cloud BCS Have?
- In Which Direction and What Capabilities Will Huawei Cloud BCS Develop?
- What Are the Specifications of VMs to Be Purchased for BCS?
- How Do I Get Access to the Partners of Huawei Cloud BCS for More Services?
- What Are the Differences Between Channel Isolation and Privacy Protection?
- How Well Does BCS Perform?
- Does BCS Support Customized Development?
- When Do I Need to Hibernate or Wake an Instance?
Service Usage
- Which Ports of a Security Group Are Opened When I Create a BCS Instance?
- How Do I Check Whether the ICAgent Is Installed for the Cluster?
- What Can I Do If I Can't Open the Blockchain Management Console?
- What Should I Do If My BCS Instance Remains in the Creating State?
- What Should I Do If a Peer Restarts Frequently with the Error Message "PanicDB not exist"?
- What Can I Do If the CPU Usage of a Blockchain Node Reaches 100%?
- Why Can't I Log In to the Blockchain Management Console?
- BCS.4009100: System Error
- How Can I Obtain Private Keys and Certificates for Enhanced Hyperledger Fabric Blockchains?
- Why Does Chaincode Instantiation Fail When I Deploy a Fabric v1.4 Instance Using a v1.19 CCE Cluster?
- Can All Blocks Be Saved As More and More Blocks Are Created?
What Can I Do If I Fail to Purchase a BCS Instance?
- General Checks
Detailed Checks
- CCE Cluster Quota Used Up
- Failed to Create a Cluster
- Failed to Create a PVC
- Cluster Already In Use
- SFS Turbo File System Quota Exceeded
- No EIP Bound
- CCE Is Abnormal
- Cluster Status Is Abnormal
- Subnet Unavailable
- Quick Deployment in Progress
- CCE Status Check Times Out
- Insufficient Master Nodes in the AZ of the CCE Cluster
Abnormal Instance Statuses
- What Can I Do If a BCS Instance Is in the Abnormal State?
- What Can I Do If a BCS Instance Is in the Unknown State?
- What Can I Do If a BCS Instance Is in the EIP abnormal State?
- What Can I Do If a BCS Instance Is in the Frozen or Cluster frozen State?
- What Can I Do If the BCS Instance and the peer-xxx StatefulSet Are Abnormal After an Organization or a Peer Is Added?
- Other Issues
Consultation
- Chaincode Management
- Data Storage to the Blockchain
- Demos and APIs
- O&M and Monitoring
- Consortium Management
- Videos
More Documents
- Managing Enhanced Hyperledger Fabric Instances
BCS FAQs
Instance Management
Consultation
- What Underlying Framework Is Used for BCS?
- What Competitive Advantages Does BCS Have?
- What Are the Specifications of VMs to Be Created for BCS?
Service Usage
- Abnormal Instance Statuses
- Other Issues
Consultation
- Demos and APIs
Instance Management
BCS FAQs
- Change History
- Developer Guide (ME-Abu Dhabi Region)
Changing Access Address
You can update the access address of an instance by IP or domain name.
Changing Address By IP
- Log in to the BCS console.
- On the Instance Management page, click the Enhanced Hyperledger Fabric tab.
- Choose More > Change Access Address on the card of a BCS instance.
- Set Updated By to IP and specify whether to Customize New Address. If you keep the default setting (No), select a new address, and click OK.
If you set Customize New Address to Yes, use a valid private network address of the cluster or a valid EIP bound to the cluster. If there is a blockchain network failure, check and modify the IP address.
Changing Address By Domain Name
Prerequisites: You have registered a domain name with the domain name registrar.
- Log in to the Domain Name Service (DNS) console.
- On the Public Zones page, click Create Public Zone, enter the Domain Name registered with the domain name registrar. For details, see Creating a Public Zone.
- In the zone list on the Public Zones page, click a domain name to display the Record Sets page. Perform the following steps to configure the record set for the domain name. For details, see How Do I Add Record Sets to Subdomains?
- In DNS, a record set is a collection of resource records that belong to the same domain name to define DNS record types and values.
- Add a prefix to the domain name in the Name field on the Add Record Set page. The prefix and the public domain name correspond to a BCS instance.
- Click Add Record Set.
- Specify the Name. Enter the access address of the BCS instance in the Value field.
To obtain the address, go to the BCS console, on the Instance Management page, choose More > Change Access Address on a BCS instance card, then record the Current Address.
- After the domain name resolution is complete, go to the BCS console.
- Set Updated By to Domain name, enter a domain name, and click OK.
