Creating a Custom Authorizer
APIG supports custom authentication of both frontend and backend requests.
- Frontend custom authentication: If you already have an authentication system, you can configure it in a function and then create a custom authorizer by using the function to authenticate API requests.
 - Backend custom authentication: You can create a custom authorizer to authenticate requests for different backend services, eliminating the need to customize APIs for different authentication systems and simplifying API development. You only need to create a function-based custom authorizer in APIG to connect to the backend authentication system.
   Custom authentication is implemented using FunctionGraph and not supported if FunctionGraph is unavailable in the selected region.
For details about custom authentication, see the API Gateway Developer Guide.
The following figure shows the process of calling APIs through custom authentication.
- You have created a function in FunctionGraph.
 - You have the FunctionGraph Administrator permission.
- Access the shared gateway console.
 - Choose API Publishing > Custom Authorizers, and click Create Custom Authorizer.
 - Set the parameters listed in Table 1.
     Table 1 Parameters for creating a custom authorizer Parameter
Name
Authorizer name.
Type
- Frontend: Authenticates access to APIs.
 - Backend: Authenticates access to backend services.
Function URN
Select a FunctionGraph function.
Identity Sources
Request parameters for authentication. You can add headers and query strings. Header names are case-insensitive.
This parameter is mandatory only if you set Type to Frontend, and Max. Cache Age (s) is greater than 0. When the cache is used, this parameter is used as a search criterion to query authentication results.
Max. Cache Age (s)
The time for caching authentication results.
Value 0 means that authentication results will not be cached. The maximum value is 3600.
Send Request Body
Determine whether to send the body of each API request to the authentication function. If you enable this option, the request body will be sent to the authentication function in the same way as the headers and query strings.
User Data
Customized request parameters to be used together with Identity Sources when APIG invokes a function.
 - Click OK.
