url_encode
This function is used to encode a string into the application/x-www-form-urlencoded MIME format.
Syntax
url_encode(string <input>[, string <encoding>])
Parameters
| Parameter | Mandatory | Type | Description |
| input | Yes | STRING | String to be entered |
| encoding | No | STRING | Encoding format. Standard encoding formats such as GBK and UTF-8 are supported. If this parameter is not specified, UTF-8 is used by default. |
Return Values
The return value is of the STRING type.
If the value of input or encoding is NULL, NULL is returned.
Example Code
The value Example+for+url_encode+%3A%2F%2F+dsf%28fasfs%29 is returned.
select url_encode('Example for url_encode:// dsf(fasfs)', 'GBK'); What is your overall rating for this page?
