rank
This function is used to return the rank of a value in a set of values. When multiple values share the same rank, the next rank in the sequence is not consecutive.
Restrictions
The restrictions on using window functions are as follows:
- Window functions can be used only in select statements.
- Window functions and aggregate functions cannot be nested in window functions.
- Window functions cannot be used together with aggregate functions of the same level.
Syntax
rank() over ([partition_clause] [orderby_clause])
Parameters
Parameter |
Mandatory |
Description |
partition_clause |
No |
Partition. Rows with the same value in partition columns are considered to be in the same window. |
orderby_clause |
No |
It is used to specify how data is sorted in a window. |
Return Values
The return value is of the INT type.
If the value of a is NULL, NULL is returned.
Example Code
CREATE TABLE logs ( cookieid string, createtime string, pv INT ) ROW FORMAT DELIMITED FIELDS TERMINATED BY ',' stored as textfile;
Adds the following data:
cookie1 2015-04-10 1 cookie1 2015-04-11 5 cookie1 2015-04-12 7 cookie1 2015-04-13 3 cookie1 2015-04-14 2 cookie1 2015-04-15 4 cookie1 2015-04-16 4 cookie2 2015-04-10 2 cookie2 2015-04-11 3 cookie2 2015-04-12 5 cookie2 2015-04-13 6 cookie2 2015-04-14 3 cookie2 2015-04-15 9 cookie2 2015-04-16 7
Example: Groups all records by cookieid, sorts them by pv in descending order, and returns the sequence number of each row in the group. An example command is as follows:
select cookieid, createtime, pv, rank() over(partition by cookieid order by pv desc) as rank from logs where cookieid = 'cookie1'; -- Result: cookie1 2015-04-12 7 1 cookie1 2015-04-11 5 2 cookie1 2015-04-16 4 3 (third in parallel) cookie1 2015-04-15 4 3 cookie1 2015-04-13 3 5 (skip 4 and start from 5) cookie1 2015-04-14 2 6 cookie1 2015-04-10 1 7
