percent_rank
This function is used to return the value of the column specified in the ORDER BY clause of a window, expressed as a decimal between 0 and 1. It is calculated as (the rank value of the current row within the group – 1) divided by (the total number of rows in the group – 1).
Restrictions
The restrictions on using window functions are as follows:
- Window functions can be used only in select statements.
- Window functions and aggregate functions cannot be nested in window functions.
- Window functions cannot be used together with aggregate functions of the same level.
Syntax
percent_rank() over([partition_clause] [orderby_clause])
Parameters
| Parameter | Mandatory | Description |
| partition_clause | No | Partition. Rows with the same value in partition columns are considered to be in the same window. |
| orderby_clause | No | It is used to specify how data is sorted in a window. |
Return Values
The return value is of the DOUBLE type.
Example Code
Example data
CREATE EXTERNAL TABLE salary ( dept STRING, -- Department name userid string, -- Employee ID sal INT -- Salary ) ROW FORMAT DELIMITED FIELDS TERMINATED BY ',' stored as textfile;
Adds the following data:
d1,user1,1000 d1,user2,2000 d1,user3,3000 d2,user4,4000 d2,user5,5000
Example: Calculates the percentage ranking of employees' salaries in a department.
select dept, userid, sal,
percent_rank() over(partition by dept order by sal) as pr2
from salary;
-- Result analysis:
d1 user1 1000 0.0 -- (1-1)/(3-1)=0.0
d1 user2 2000 0.5 -- (2-1)/(3-1)=0.5
d1 user3 3000 1.0 -- (3-1)/(3-1)=1.0
d2 user4 4000 0.0 -- (1-1)/(2-1)=0.0
d2 user5 5000 1.0 -- (2-1)/(2-1)=1.0 What is your overall rating for this page?
