Setting the Retention Period for Multiversion Backup Data
Updated on 2024-07-04 GMT+08:00
Function
After multiversion is enabled, backup data is retained for seven days by default. You can change the retention period by setting system parameter dli.multi.version.retention.days. Multiversion data out of the retention period will be automatically deleted when the insert overwrite or truncate statement is executed. You can also set table attribute dli.multi.version.retention.days to adjust the retention period when adding a column or modifying a partitioned table.
For details about the syntax for enabling or disabling the multiversion function, see Enabling or Disabling Multiversion Backup.
Currently, the multiversion function supports only OBS tables created using the Hive syntax. For details about the syntax for creating a table, see Creating an OBS Table Using the Hive Syntax.
Syntax
ALTER TABLE [db_name.]table_name
SET TBLPROPERTIES ("dli.multi.version.retention.days"="days");
Keywords
  • TBLPROPERTIES: This keyword is used to add a key/value property to a table.
Parameters
Table 1 Parameters
db_name
Database name, which consists of letters, digits, and underscores (_). The value cannot contain only digits or start with a digit or underscore (_).
table_name
Table name
days
Date when the multiversion backup data is reserved. The default value is 7 days. The value ranges from 1 to 7 days.
Precautions
Example
Set the retention period of multiversion backup data to 5 days.
ALTER TABLE test_table
SET TBLPROPERTIES ("dli.multi.version.retention.days"="5");
