MERGE INTO
Updated on 2025-01-09 GMT+08:00
Function
This command is used to query another table based on the join condition of a table or subquery. If UPDATE or DELETE is executed for the table matching the join condition, and INSERT is executed if the join condition is not met. This command completes the synchronization requiring only one full table scan, delivering higher efficiency than INSERT plus UPDATE.
Precautions
To merge partitioned tables, set spark.sql.forcePartitionPredicatesOnPartitionedTable.enabled to false.
Syntax
MERGE INTO [database_name.]table_name AS target_alias
USING (sub_query | tableIdentifier) AS source_alias
ON <merge_condition>
[ WHEN MATCHED [ AND <condition> ] THEN <matched_action> ]
[ WHEN NOT MATCHED [ AND <condition> ] THEN <not_matched_action> ]
<merge_condition> =A equal bool condition
<matched_action> =
DELETE |
UPDATE SET * |
UPDATE SET column1 = expression1 [, column2 = expression2 ...]
<not_matched_action> =
INSERT * |
INSERT (column1 [, column2 ...]) VALUES (value1 [, value2 ...])
Parameter Description
Table 1 Parameter descriptions of MERGE INTO
database_name
Name of the database, consisting of letters, numbers, and underscores (_)
table_name
Name of the table in the database, consisting of letters, numbers, and underscores (_)
bucket_name
OBS bucket name
tbl_path
Storage location of the Delta table in the OBS bucket
target_alias
Alias of the target table
sub_query
Subquery.
source_alias
Alias of the source table or source expression
merge_condition
Condition for associating the source table or expression with the target table.
condition
Filtering condition. This parameter is optional.
matched_action
DELETE or UPDATE operation to be performed when conditions are met.
not_matched_action
INSERT operation to be performed when conditions are not met.
Required Permissions
  • SQL permissions
    Table 2 Permissions required for executing MERGE INTO
    Permission Description
    UPDATE permission on a table
    ALTER permission on a table
    DELETE permission on a table
  • Fine-grained permissions: dli:table:update, dli:table:insertIntoTable, and dli:table:delete
  • Metadata services provided by LakeFormation. Refer to the LakeFormation documentation for details on permission configuration.
Examples
  • Update some fields.
    create table h0(id int, comb int, name string, price int) using delta location 'obs://bucket_name0/db0/h0';
    create table s0(id int, comb int, name string, price int) using delta location 'obs://bucket_name0/db0/s0';
    insert into h0 values(1, 1, 'h1', 1);
    insert into s0 values(1, 1, 's1', 1),(2, 2, 's2', 2);
    // Method 1
    merge into h0 using s0
    on h0.id = s0.id
    when matched then update set h0.id = s0.id, h0.comb = s0.comb, price = s0.price * 2;
    // Method 2
    on h0.id = s0.id
    when matched then update set id = s0.id,
    name = s0.name,
    comb = s0.comb + h0.comb,
    price = s0.price + h0.price;
  • Update and insert default fields.
    create table h0(id int, comb int, name string, price int, flag boolean) using delta location 'obs://bucket_name0/db0/h0';
    create table s0(id int, comb int, name string, price int, flag boolean) using delta location 'obs://bucket_name0/db0/s0';
    insert into h0 values(1, 1, 'h1', 1, false);
    insert into s0 values(1, 2, 's1', 1, true);
    insert into s0 values(2, 2, 's2', 2, false);
    merge into h0 as target
    using (
    select id, comb, name, price, flag from s0
    ) source
    on target.id = source.id
    when matched then update set *
    when not matched then insert *;
  • Update and delete data based on multiple conditions.
    insert into h0 values(2, 2, 'h2', 1, false);
    insert into s0 values(1, 1, 's1', 1, true);
    insert into s0 values(3, 3, 's3', 3, false);
    merge into h0
    using (
    ) source
    on h0.id = source.id
    when matched and h0.flag = false then update set id = source.id, comb = h0.comb + source.comb, price = source.price * 2
    when matched and h0.flag = true then delete
System Response
You can view the result in driver logs or on the client.
