UPDATE
Function
This command updates a Delta table based on column expressions and optional filter conditions.
Syntax
UPDATE [database_name.]table_name|DELTA.`obs://bucket_name/tbl_path`
SET column = EXPRESSION(,column = EXPRESSION)
[ WHERE boolExpression]
Parameter Description
| Parameter | Description |
| database_name | Name of the database, consisting of letters, numbers, and underscores (_) |
| table_name | Name of the table in the database, consisting of letters, numbers, and underscores (_) |
| bucket_name | OBS bucket name |
| tbl_path | Storage location of the Delta table in the OBS bucket |
| column | Target column to be updated |
| EXPRESSION | Expression of the source table column to be updated in the target table |
| boolExpression | Filter condition expression |
Required Permissions
- SQL permissions
| Permission Description |
| UPDATE permission on a table |
- Fine-grained permission: dli:table:update
- Metadata services provided by LakeFormation. Refer to the LakeFormation documentation for details on permission configuration.
Examples
update delta_table0 set price = price + 20 where id = 1; update delta.`obs://bucket0/db0/delta_table1` set price = price *2, name = 'a2' where part0='xx' and id = 2;
System Response
You can view the result in driver logs or on the client.
