Help Center/
      Virtual Private Cloud/
        User Guide (Kuala Lumpur Region)/
        FAQ/
        VPC Peering Connections/
      Can a VPC Peering Connection Connect VPCs in Different Regions?
        Updated on 2024-04-11 GMT+08:00
A VPC peering connection only can connect VPCs in the same region.
  Figure 1 shows an application scenario of VPC peering connections.
- There are two VPCs (VPC-A and VPC-B) in region A that are not connected.
 - Service servers (ECS-A01 and ECS-A02) are in VPC-A, and database servers (RDS-B01 and RDS-B02) are in VPC-B. The service servers and database servers cannot communicate with each other.
- You need to create a VPC peering connection (peering-AB) between VPC-A and VPC-B so the service servers and database servers can communicate with each other.
   Parent topic: VPC Peering Connections
