Configuring the Independent Attribute
User admin or administrators who are bound to the Manager_administrator role can configure the Independent attribute function on FusionInsight Manager so that common users (all service users in the cluster) can set or cancel their own Independent attributes.
After the Independent attribute switch is turned on, users need to log in and set the Independent attribute.
Restrictions
- Administrators cannot set or cancel the Independent attribute of a user.
 - Administrators cannot obtain the authentication credentials of independent users.
You have obtained the required administrator username and password.
Configuring the Independent Attribute Function Switch
- Log in to FusionInsight Manager as user admin or a user bound to the Manager_administrator role.
 - Choose System > Permission > Security Policy > Configuration Independent.
 - Open or Close the Independent Attribute, enter the password as prompted and click OK.
 - After the authentication succeeds, and the OMS configuration is modified, click Finish.
     After the Independent attribute function switch is closed:
- A user who has the attribute can cancel it by moving the cursor to the username in the upper right corner of the page and choose Cancel Independent from the displayed shortcut menu. After the cancellation, the user cannot set the attribute again. After the attribute is cancelled, existing independent tables will retain the attribute. However, the user cannot create independent tables again.
 - Users without this attribute cannot set or cancel the attribute.
- Log in to FusionInsight Manager as a user.
     After the Independent attribute is set by a user, administrators cannot initialize the password of the user. If the user password is forgotten, the password cannot be retrieved.
User admin cannot set the Independent attribute.
 - Move the cursor to the username in the upper right corner of the page.
 - Choose Set Independent or Cancel Independent from the displayed shortcut menu.
     - If the Independent attribute function switch is turned on, and the attribute of the user is set, Cancel Independent is displayed in the shortcut menu.
 - If the Independent attribute function switch is turned on, and the attribute of the user is cancelled, Set Independent is displayed in the shortcut menu.
 - If the Independent attribute function switch is turned off, and the attribute of the user is set, Cancel Independent is displayed in the shortcut menu.
 - If the Independent attribute function switch is turned off, and the attribute of the user is cancelled, no options are displayed in the shortcut menu.
 - Enter the password as prompted and click OK.
 - After the authentication succeeds, click OK in the confirmation dialog box.
