Help Center/
Cloud Container Engine/
User Guide (Kuala Lumpur Region)/
Clusters/
Upgrading a Cluster/
Troubleshooting for Pre-upgrade Check Exceptions/
Key GPU Add-on Parameters
Check Items
Check whether the configuration of the CCE AI Suite add-on in a cluster has been intrusively modified. If so, upgrading the cluster may fail.
Solution
- Use kubectl to access the cluster.
- Run the following command to obtain the add-on instance details:
kubectl get ds nvidia-driver-installer -nkube-system -oyaml
- Check whether the UpdateStrategy value is changed to OnDelete. If so, change it back to RollingUpdate.
- Check whether the NVIDIA_DRIVER_DOWNLOAD_URL value is the same as the GPU driver version on the add-on page. If not, correct the version on the add-on page.
Parent topic: Troubleshooting for Pre-upgrade Check Exceptions
