Help Center/ Cloud Container Engine/ User Guide (Kuala Lumpur Region)/ Network/ DNS/ Using NodeLocal DNSCache to Improve DNS Performance
Challenges
When the number of DNS requests in a cluster increases, the load of CoreDNS increases and the following issues may occur:
  • Increased delay: CoreDNS needs to process more requests, which may slow down the DNS query and affect service performance.
  • Increased resource usage: To ensure DNS performance, CoreDNS requires higher specifications.
Solution
To minimize the impact of DNS delay, deploy NodeLocal DNSCache in the cluster to improve the networking stability and performance. NodeLocal DNSCache runs a DNS cache proxy on cluster nodes. All pods with DNS configurations use the DNS cache proxy running on nodes instead of the CoreDNS service for domain name resolution. This reduces CoreDNS's load and improves the cluster DNS performance.
After NodeLocal DNSCache is enabled, a DNS query goes through the path as shown below.
Figure 1 NodeLocal DNSCache query path
The resolution rules are as follows:
  • 1. By default, the pods with DNSConfig injected use NodeLocal DNSCache to resolve requested domain names.
  • 2. If NodeLocal DNSCache cannot resolve domain names, it will ask CoreDNS for resolution.
  • 3. CoreDNS uses the DNS server in the VPC to resolve the domain names out of the cluster.
  • 4. If a pod with DNSConfig injected cannot access NodeLocal DNSCache, CoreDNS will resolve the domain name.
  • 5. By default, CoreDNS resolves domain names for the pods without DNSConfig injected.
Notes and Constraints
Installing the Add-on
CCE provides add-on NodeLocal DNSCache that simplifies the installation of NodeLocal DNSCache.
NodeLocal DNSCache serves as a transparent caching proxy for CoreDNS and does not provide plug-ins such as hosts or rewrite. If you want to enable these plug-ins, modify the CoreDNS configurations.
  1. (Optional) Modify the CoreDNS configuration so that the CoreDNS preferentially uses UDP to communicate with the upstream DNS server.
    The NodeLocal DNSCache uses TCP to communicate with the CoreDNS. The CoreDNS communicates with the upstream DNS server based on the protocol used by the request source. However, the cloud server does not support TCP. To use NodeLocal DNSCache, modify the CoreDNS configuration so that UDP is preferentially used to communicate with the upstream DNS server, preventing resolution exceptions.
    Perform the following operations. In the forward add-on, specify prefer_udp as the protocol used by requests. After the modification, CoreDNS preferentially uses UDP to communicate with the upstream system.
    2. In the navigation pane, choose Add-ons. Then, click Edit under CoreDNS.
    3. Edit the advanced configuration under Parameters and modify the following content in the plugins field:
          "configBlock": "prefer_udp",
          "name": "forward",
          "parameters": ". /etc/resolv.conf"
      Corefile:
      Corefile: |-
        .:5353 {
            bind {$POD_IP}
            cache 30 {
                servfail 5s
            errors
            health {$POD_IP}:8080
            kubernetes cluster.local in-addr.arpa ip6.arpa {
                pods insecure
                fallthrough in-addr.arpa ip6.arpa
            loadbalance round_robin
            prometheus {$POD_IP}:9153
            forward . /etc/resolv.conf {
                prefer_udp
            reload
            ready {$POD_IP}:8081
  2. Log in to the CCE console and click the cluster name to access the cluster console. Choose Add-ons in the navigation pane, locate NodeLocal DNSCache on the right, and click Install.
  3. On the Install Add-on page, select the add-on specifications and set related parameters.
    • DNSConfig: After this function is enabled, a DNSConfig admission controller will be created. The controller intercepts pod creation requests in the namespace labeled with node-local-dns-injection=enabled based on admission webhooks and automatically configures DNSConfig for pods. If this function is disabled or the pod belongs to a non-target namespace, you must manually configure DNSConfig for the pod.
      After automatic injection is enabled, you can customize the following configuration items for DNSConfig (supported when the add-on version is 1.6.7 or later):
      If DNSConfig has been configured in the pod when automatic injection is enabled, DNSConfig in the pod will be used first.
      • (Optional) IP Address of DNS Server: IP address list of the DNS server obtained when the container resolves the domain name. NodeLocal DNSCache and CoreDNS IP addresses are added by default. You have the option to add an additional IP address, but duplicates will be removed.
      • (Optional) Search Domain: a search list for host-name lookup. When a domain name cannot be resolved, DNS queries will be attempted combining the domain name with each domain in the search list in turn until a match is found or all domains in the search list are tried. You can add up to three extra search domains, but any duplicates will be removed.
      • (Optional) ndots: specifies that if a domain name has fewer periods (.) than the specified value of ndots, it will be combined with the search domain list for DNS query. If the domain name still cannot be resolved, it will be used for DNS query. The system will perform a DNS query on a domain name if the number of periods (.) in it is greater than or equal to the value of ndots. If the domain name cannot be resolved correctly, the system will sequentially combine it with the search domain list and then perform a DNS query.
    • Target Namespace: This parameter is available after DNSConfig is enabled. Only NodeLocal DNSCache of v1.3.0 or later supports this function.
      • Enable All: CCE adds the node-local-dns-injection=enabled label to all created namespaces excluding built-in ones (such as kube-system), identifies namespace creation requests, and automatically adds the label to newly created namespaces.
      • Manually Configure: You must manually add the node-local-dns-injection=enabled label to the namespaces requiring the injection of DNSConfig. For details, see Managing Namespace Labels.
  4. Click Install.
By default, application requests are sent through the CoreDNS proxy. To use node-local-dns as the DNS cache proxy, use any of the following methods:
  • Auto injection: Automatically configure the dnsConfig field of the pod when creating the pod. (This function is not available for pods in system namespaces such as kube-system.)
  • Manual configuration: Manually configure the dnsConfig field of the pod.
Auto Injection
To enable auto injection, perform the following operations:
  1. Install the NodeLocal DNSCache add-on and enable auto DNSConfig injection. For details, see Installing the Add-on.
  2. Use kubectl to access the cluster and add the node-local-dns-injection=enabled label to the namespace. For example, run the following command to add the label to the default namespace:
    kubectl label namespace default  node-local-dns-injection=enabled
  3. Create a workload in the namespace with auto injection enabled. For details, see Creating a Deployment.
    NOTICE:
    The pods for which auto injection is enabled must meet the following requirements:
    • The new pod does not run in system namespaces such as kube-system and kube-public.
    • The node-local-dns-injection=disabled label for disabling DNS injection is not added to the new pod.
    • The new pod's DNSPolicy is ClusterFirstWithHostNet. Alternatively, the pod does not use the host network and DNSPolicy is ClusterFirst.
  4. Check the pod configuration.
    kubectl get pod <pod_name> -oyaml
    After auto injection is enabled, the following dnsConfig settings will be automatically added to the created pod. In addition to the NodeLocal DNSCache IP address 169.254.20.10, the CoreDNS IP address 10.247.3.10 is added to nameservers, ensuring high availability of the service DNS server.
      dnsConfig:
        nameservers:
          - 169.254.20.10
          - 10.247.3.10
        searches:
          - default.svc.cluster.local
          - svc.cluster.local
          - cluster.local
        options:
          - name: timeout
            value: ''
          - name: ndots
            value: '5'
          - name: single-request-reopen
Manual Configuration
Manually add the dnsConfig settings to pods.
  1. Use kubectl to access the cluster. For details, see Connecting to a Cluster Using kubectl.
  2. Create a pod and add the NodeLocal DNSCache IP address 169.254.20.10 to nameservers in dnsConfig.
    Create a nginx.yaml file. The following shows an example:
    apiVersion: v1
    kind: Pod
      containers:
      - image: nginx:alpine
      dnsConfig:
        nameservers:
        - 169.254.20.10
        - 10.247.3.10
        searches:
        - svc.cluster.local
        - cluster.local
        options:
        - name: ndots
          value: '2'
      imagePullSecrets:
      - name: default-secret
  3. Run the following command to create a pod:
    kubectl create -f nginx.yaml
Common Issues
  • How Do I Prevent Auto DNSConfig Injection on a Specific Pod?
    Solution:
    Add node-local-dns-injection: disabled to the labels field in the pod template. Example:
    apiVersion: apps/v1
    kind: Deployment
      namespace: default
      replicas: 2
      selector:
        matchLabels:
          app: test
      template:
          labels:
            app: test
            node-local-dns-injection: disabled   # Prevent auto DNSConfig injection.
          containers:
            - name: container-1
              image: nginx:latest
              imagePullPolicy: IfNotPresent
          imagePullSecrets:
