Help Center/ Cloud Container Engine/ User Guide (Kuala Lumpur Region)/ Network/ DNS/ Changing the Default NodeLocal DNSCache Port
Updated on 2025-07-07 GMT+08:00
NodeLocal DNSCache defaults to using port 8080 on the host node, but this can cause conflicts with other services sharing the same port. This section describes how to change the default NodeLocal DNSCache port.
  2. Choose Add-ons in the navigation pane, find the NodeLocal DNSCache add-on on the right, and click Install. If this add-on has been installed in the cluster, click Edit.
  3. On the displayed page, configure parameters and click Installation Using YAML in the upper part of the page. If this add-on has been installed in the cluster, click Edit YAML.
    To simplify configuration, configure other parameters on the console, and then change the port number in the YAML file. For more information about other parameters, see NodeLocal DNSCache.
  4. Configure both parameters to the specified port number, ensuring they have the same value.
    1. Search for the healthPort parameter and change its value to a specified port number, for example, 8081.
    2. Search for the cluster.local parameter and change the value of port in the array to the specified port number, for example, 8081.
  5. Click OK.
