On this page
Show all
Creating a Disk Backup Vault
Updated on 2022-08-16 GMT+08:00
This section describes how to create a disk backup vault.
  1. In the upper right corner of the page, click Create Disk Backup Vault.
  2. (Optional) In the disk list, select the disks you want to back up. After disks are selected, they are added to the list of selected disks.
    • The selected disks must have not been associated with a vault and must be in the Available or In-use state.
    • You can associate disks with the vault you are creating if you skip this step.
  3. Specify the vault capacity. This capacity indicates the total size of the disks that you want to associate with this vault. You need to properly plan the vault capacity, which must be at least the same as the size of the disks you want to back up. The capacity ranges from 10 GB to 10485760 GB.
  4. Determine whether to configure auto backup.
    • If you select Configure, you must then select an existing backup policy or create a new policy. After the vault is created, the system will apply the policy to this vault, and all disks associated with this vault will be automatically backed up based on this policy.
    • If you select Skip, disks associated with this vault will not be automatically backed up until you apply a backup policy to it.
  5. (Optional) Configure automatic resource association.
    • If you select Configure, in the next backup period, unprotected resources will be automatically scanned and associated with the vault, and backups will be automatically executed.
    • If you select Skip, resources will not be automatically associated with the vault you are creating.
    You can filter unprotected resources by tag. If a tag is selected, only unprotected resources having the specified tag will be associated with the vault. Or, all unprotected resources will be associated.
    Only existing tags can be selected. If no tag is available, create tags on the corresponding resource page. You can select a maximum of 5 tags to search for vaults. If you select more than one tag, the vaults containing any of the specified tags will be returned.
  6. If you have subscribed to the EPS service, add the vault to an existing enterprise project.
    EPS provides a unified method to manage cloud resources by project, allowing you to manage resources, users, and user groups in your projects. The default project name is default.
  7. (Optional) Add tags to the vault.
    A tag is represented in the form of a key-value pair. Tags are used to identify, classify, and search for vaults. Vault tags are used to filter and manage vaults only. A vault can have a maximum of 10 tags.
    Table 1 describes the parameters of a tag.
    Table 1 Tag parameter description
    Example Value
    Key
    Each tag has a unique key. You can customize the key or select the key of an existing tag created in TMS.
    A tag key:
    • Can contain 1 to 36 Unicode characters.
    • Can contain only letters, digits, hyphens (-), and underscores (_).
    Key_0001
    Value
    A tag value can be repetitive or left blank.
    A tag value:
    • Can contain 0 to 43 Unicode characters.
    Value_0001
  8. Specify a name for the vault.
    A name must contain 1 to 64 characters including digits, letters, underscores (_), or hyphens (-), for example, vault-612c.
    You can use the default name, which is in the format of vault_xxxx.
  9. Complete the creation as prompted.
  10. Go back to the Cloud Disk Backups page. You can see the created vault in the vault list.
    You can associate disks to the new vault or perform backup for the disks. For details, see Vault Management.
