Help Center/ MaaS/ Model Calling/ Model API Calling Specifications/ Obtaining the Model List (Models/GET)
Updated on 2026-09-10 GMT+08:00
This chapter describes how to query the model list through the Models API.
This function is only available in the CN-Hong Kong region.
API Information
Table 1 API information
Example Value
API Host
API URL for calling the model service.
https://api-ap-southeast-1.modelarts-maas.com/v2/models
Creating a Request
  • Authentication description
    MaaS inference services support API key authentication. The authentication header is in the following format:
    'Authorization': 'Bearer API key of the region where the service is deployed'
  • Response parameters
    Table 2 Response parameters
    Type
    object
    string
    Type-list: (The queried information is listed.)
    data
    Array
    Model information of the model service. The main parameters are as follows:
    • id: model ID used when calling the API to create a request.
    • object: model type.
    • created: creation timestamp.
Example Request
The following uses the requests library of Python to send an HTTP GET request to obtain model information.
Replace yourApiKey with the actual API key. For more information, see Manage API Keys.
import requests
url = "https://api-ap-southeast-1.modelarts-maas.com/v2/models"
headers = {"Authorization": "Bearer yourApiKey"}
response = requests.request("GET", url, headers=headers)
print(response.text)
Response Example
    "object": "list",
    "data": [
            "id": "deepseek-v4-flash",
            "object": "list",
            "created": 0,
            "owned_by": "system"
            "id": "deepseek-v4-pro",
            "object": "list",
            "created": 0,
            "id": "glm-5.1",
            "object": "list",
            "created": 0,
            "id": "glm-5.2",
            "object": "list",
            "created": 0,
