Updated on 2026-11-11 GMT+08:00
Anthropic-compatible APIs
This function is only supported in CN-Hong Kong.
API Information
Example Value
API URL
API URL for calling the model service.
https://api-ap-southeast-1.modelarts-maas.com/anthropic/v1/messages
Authentication request
Provides the server with identity authentication/authorization credentials.
"x-api-key":"$MaaS_API_Key"
Supported Models
You can log in to the MaaS console and enable the following models on the Model Inference > Real-Time Inference > Built-in Services page. On the model details page in the Model Square, you can view detailed information about the models.
Model Series
Model Version
Supported Region
Value of model
GLM
GLM-5.3
CN-Hong Kong
glm-5.3
GLM-5.1
CN-Hong Kong
glm-5.1
GLM-5.2
CN-Hong Kong
glm-5.2
DeepSeek
DeepSeek-V4-Flash
CN-Hong Kong
deepseek-v4-flash
DeepSeek-V4.1-Flash
CN-Hong Kong
deepseek-v4.1-flash
DeepSeek-V4.1-Flash-1017
CN-Hong Kong
deepseek-v4.1-flash-1017
Request Parameters
Category
Type
Mandatory
General
model
string
Yes
Definition
Model parameter used for generating content. For details about its value, see the model values in Supported models.
N/A
Range
Default Value
N/A
system
string
No
Definition
System prompt, which can be used to assign a specific goal or role to the model.
N/A
Range
N/A
Default Value
N/A
messages
object[]
Yes
Definition
List of messages in a dialog. Different models support different types of messages.
messages.role
enum<string>
Yes
Definition
Role that sends a message.
N/A
Range
  • user
  • assistant: A message returned by the model.
Default Value
N/A
messages.content
string/array
Yes
Definition
Message sent by the current role.
N/A
Range
N/A
Default Value
N/A
messages.content.type
enum<string>
Yes
Definition
Message type.
N/A
Range
  • text: text messages.
  • tool_use: tool calls.
  • tool_result: tool call results.
  • image: Image type.
Default Value
N/A
Image information
messages.content.source
object
No
Definition
This parameter specifies the image information.
  • This parameter is supported by DeepSeek-V4.1-Flash-1017 and DeepSeek-V4.1-Flash.
  • This parameter is mandatory when messages.content.type is image.
  • Image limitations: A maximum of 600 images is supported. Each image referenced by a publicly accessible URL must be no larger than 32 MB. There are no resolution restrictions, but a resolution below 4096 × 2160 is recommended. Supported formats are JPEG, PNG, GIF, and WebP. When uploading images in Base64-encoded format, the entire request body must not exceed 5 MB. You are advised to use a publicly accessible image URL.
messages.content.source.type
string
No
Definition
This parameter specifies the source of the image.
Range
  • base64: The image is passed in Base64 format.
  • url: The image is passed in URL format.
Default Value
N/A
messages.content.source.media_type
string
No
Definition
This parameter specifies the MIME type.
This parameter is mandatory when images are passed in Base64 format.
Range
  • image/png
  • image/jpeg
  • image/webp
  • image/gif
Default Value
N/A
messages.content.source.data
string
No
Definition
This parameter specifies the Base64-encoded image data.
"iVBORw0KGgoAAAANSUhEUgAA..."
Range
N/A
Default Value
N/A
messages.content.source.url
string
No
Definition
This parameter specifies the public URL of the image.
This parameter is mandatory when the image is transferred through a public URL.
Range
N/A
Default Value
N/A
Tool call result
messages.content.tool_use_id
string
Yes
Definition
ID of the tool called by the model.
This parameter is mandatory when messages.content.type is set to tool_result.
Range
N/A
Default Value
N/A
messages.content.content
string
No
Definition
Content obtained after the tool is called.
Range
N/A
Default Value
N/A
Deep thinking control
thinking
object
No
Definition
Controls whether to enable the deep thinking mode for a model.
For details about the supported models, see Thinking Control for Deep Thinking Models.
thinking.type
string
Yes
Definition
Range
  • enabled: The deep thinking mode is enabled. The model must think before answering.
  • disabled: The deep thinking mode is disabled. The model directly answers questions without thinking.
Default Value
The default value varies depending on the model. For details, see Thinking Control for Deep Thinking Models.
Model output behavior configuration
max_tokens
integer/null
No
Definition
Maximum length of the content part of the model answer. After this parameter is set, the token length of the model output content does not exceed the value of max_tokens.
N/A
Range
The default value varies depending on the model. For details, see the maximum output length and maximum CoT length on the model details page.
Default Value
  • DeepSeek-V4.1-Flash-1017 and DeepSeek-V4.1-Flash: 64K
  • Other models: 4K
temperature
number
No
Definition
Sampling temperature, used to control the randomness of the content generated by the model.
A higher value (for example, greater than 1) will make the model output more random, divergent, and creative, while a lower value (for example, 0.1) will make the output more focused, deterministic, and conservative.
It is recommended that you adjust either temperature or top_p.
Range
[0,2]
Default Value
Some models apply special handling to inputs:
  • DeepSeek-V4.1-Flash-1017: The default value is 1.0.
  • DeepSeek-V4.1-Flash: The default value is 0.6.
  • DeepSeek-V4: In thinking mode, the value is always 1.0, regardless of the user input.
  • For GLM-5.3, the default value is 1.0.
For other models, the input is used if provided; otherwise, it defaults to 0.6.
top_p
float/null
No
Definition
Nucleus sampling probability threshold, used to control the diversity of the content generated by the model. Similar to the temperature parameter, it influences randomness, but offers finer control by dynamically adjusting the pool of possible tokens.
  • When set close to 0, the model samples from only the most probable tokens, resulting in very conservative and highly deterministic outputs.
  • When set close to 1, there is virtually no restriction on the vocabulary, leading to more random and divergent outputs.
Range
[0,1]
Default Value
  • DeepSeek-V4.1-Flash-1017: In non-thinking mode, the value is always 1.0.
  • GLM-5.3: Defaults to 0.95.
  • Other models: This parameter is not applicable.
stream
boolean/null
No
Definition
Determines whether the response is returned as a stream.
N/A
Range
  • false: Returns results once all content has been generated by the model.
  • true: Returns content piece by piece, ending with data: [DONE].
Default Value
false
stop_sequences
string[]
No
Definition
Stops the model from generating content when it encounters the string specified in the stop_sequences field.
The stop token does not hit the token in the CoT, but only hits the part in the formal answer content.
N/A
Range
N/A
Default Value
N/A
reasoning_effort
string
No
Definition
Controls the reasoning intensity.
  • This field takes effect only in thinking mode.
  • Involved models: DeepSeek-V4 series, GLM-5.2, GLM-5.3, GLM-5.2-Arkts-Spark, DeepSeek-V4.1-Flash, and DeepSeek-V4.1-Flash-1017
Range
  • none: disable the thinking mode.
  • low: enhanced reasoning
  • high or max: deep reasoning
GLM-5.3:
  • max or high: deep reasoning
GLM-5.2-Arkts-Spark and GLM-5.2:
  • max or xhigh: deep reasoning
  • high, medium, or low: enhanced reasoning
  • minimal or none: The model gives up thinking.
    • xhigh is mapped to max.
    • low or medium is mapped to high.
DeepSeek-V4 series: max or high
Default Value
GLM-5.2-Arkts-Spark, GLM-5.3, and GLM-5.2: max
DeepSeek-V4.1-Flash-1017, DeepSeek-V4.1-Flash, and DeepSeek-V4 series: high
Tool calling
tools
array
No
Definition
List of tools available for the model to call, which may be included in the model's response. Configure this structure when you require the model to specify the tools to be called.
N/A
tools.name
string
Yes
Definition
Name of the function to be called.
N/A
Range
N/A
Default Value
N/A
tools.description
string
No
Definition
Description of the function to be called. The model will determine if the tool is needed for the current task based on this description.
N/A
Range
N/A
Default Value
N/A
tools.input_schema
object
No
Definition
Function request parameters, described in JSON format. Example:
  "type": "object",
  "properties": {
    "parameter name": {
      "type": "parameter type",
      "description": "parameter description"
  "required": ["mandatory parameters"]
Parameters must conform to JSON specifications.
N/A
Response Parameters (Non-Streaming)
Type
id
string
Definition
Unique identifier of this request.
Range
N/A
type
enum<string>
Definition
The type of the response message.
Range
message
role
string
Definition
The role of the author of this message.
Range
model
string
Definition
Model parameter used in this request.
Range
content
array
Definition
Content generated by the model.
content.type
enum<string>
Definition
Type of the generated content.
Range
  • thinking: deep thinking.
Deep thinking response (type: thinking)
content.thinking
string
Definition
Deep thinking content of the model.
Range
N/A
content.signature
string
Definition
Complete encrypted thinking content.
Range
N/A
Formal reply (type: text)
content.text
string
Definition
Formal reply content of the model.
Range
N/A
Tool input response (type: tool_use)
content.id
string
Definition
ID of the tool called.
Range
N/A
content.name
string
Definition
Name of the tool called.
Range
N/A
content.input
object
Definition
Structured input required to call the tool.
Range
N/A
stop_reason
enum<string>/null
Definition
Reason why the model stops generating tokens.
Range
  • end_turn: The model output ends naturally.
  • max_tokens: The model output triggers the max_tokens limit.
  • stop_sequence: The model output token matches the token in stop_sequence.
  • tool_use: The model determines that a tool needs to be called.
stop_sequence
string/null
Definition
Indicates which custom stop_sequence was matched. The model returns null if none were matched.
Range
N/A
usage
object
Definition
Number of tokens consumed by this request.
Range
N/A
usage.output_tokens
integer
Definition
The number of tokens consumed by the model to generate the completion response.
Range
N/A
usage.input_tokens
integer
Definition
The number of tokens consumed by the model to process the input.
Range
N/A
usage.cache_creation_input_tokens
integer
Definition
Number of input tokens newly written to the cache in this request.
Range
N/A
usage.cache_read_input_tokens
integer
Definition
Number of input tokens served from the cache in this request.
Range
N/A
usage.service_tier
string
Definition
Service tier used for this request.
Range
default
usage.total_tokens
integer
Definition
The total number of tokens consumed by the model to process the input and generate the output.
Range
N/A
Response Parameters (Streaming)
Type
event
Definition
ID of a returned message.
Range
  • message_start: the first chunk.
  • content_block_start: the start chunk of the formal reply.
  • content_block_delta: contains the text of the formal reply, input_json for tool calls, and thinking for deep thinking.
  • content_block_stop: indicates that a segment of content has been fully output.
  • message_delta: contains stop_reason, stop_sequence, and usage information.
  • message_stop: indicates that all messages have been returned.
event: message_start
type
string
Definition
Type of the chunk.
Range
message
object[]
Definition
Response message.
message.id
string
Definition
Range
N/A
message.type
string
Definition
Range
message
message.role
string
Definition
The role of the information.
Range
assistant
message.model
string
Definition
Model parameter called.
Range
message.stop_sequence
string/null
Definition
Hit stop sequence.
Range
If no match is found in the cache, the output is null.
message.usage
object
Definition
Token usage statistics of the current request.
message.usage.input_tokens
integer
Definition
Range
N/A
message.usage.output_tokens
integer
Definition
Range
N/A
message.usage.cache_creation_input_tokens
integer
Definition
Range
N/A
message.usage.cache_read_input_tokens
integer
Definition
Range
N/A
message.usage.service_tier
string
Definition
Range
default
message.usage.total_tokens
integer
Definition
Range
N/A
message.content
array
Definition
message.stop_reason
enum<string>/null
Definition
Reason why the model stops outputting.
Range
If the model does not stop outputting, the value is null.
event: content_block_start
type
string
Definition
Type of the chunk.
Range
index
integer
Definition
Index of the current element.
Range
N/A
content_block
object
Definition
Details about the content generated by the model.
content_block.type
string
Definition
Type of the content generated by the model.
Range
text
content_block.thinking
string
Definition
Range
N/A
content_block.text
string
Definition
Range
N/A
content_block.id
string
Definition
Range
N/A
content_block.name
string
Definition
Range
N/A
content_block.input
object
Definition
Range
N/A
event: content_block_delta
type
string
Definition
Type of the chunk.
Range
index
integer
Definition
Range
N/A
delta
object
Definition
Incremental output from the model.
delta.type
string
Definition
Incremental content type.
Range
text_delta
delta.text
string
Definition
Incremental text output from the model.
Range
N/A
delta.partial_json
string
Definition
JSON data required for tool calls during streaming output.
event: content_block_stop
type
string
Definition
Type of the chunk.
Range
index
integer
Definition
Range
N/A
event: message_delta
type
string
Definition
Type of the chunk.
Range
delta
object
Definition
Incremental content of the message.
delta.stop_sequence
string/null
Definition
Hit stop sequence.
Range
If no match is found in the cache, the model returns null.
delta.stop_reason
string
Definition
Range
usage
enum<string>/null
Definition
usage.output_tokens
integer
Definition
Range
N/A
usage.input_tokens
integer
Definition
Range
N/A
integer
Definition
Range
N/A
integer
Definition
Range
N/A
usage.total_tokens
integer
Definition
Range
N/A
event: message_stop
type
string
Definition
Type of the chunk.
Range
Model
thinking.type Default Value
thinking.type Options
GLM-5.3
enabled
enabled
GLM-5.2
GLM-5.1
enabled
  • enabled
  • disabled
DeepSeek-V4.1-Flash
DeepSeek-V4-Flash
enabled
  • enabled
  • disabled
Tool Choices for Models
Model
Supported Tool Choice
GLM-5.1
GLM-5.2
GLM-5.3
  • none
  • auto
  • named
DeepSeek-V4.1-Flash
DeepSeek-V4-Flash
  • none
  • auto
  • named
Example 1: Streaming Output
Example request:
import requests
import json
if __name__ == '__main__':
    url = "https://api-ap-southeast-1.modelarts-maas.com/anthropic/v1/messages" # API URL
    api_key = "MAAS_API_KEY"  # Replace MAAS_API_KEY with the obtained API key.
    # Send request.
    headers = {
        'Content-Type': 'application/json',
        'Authorization': f'Bearer {api_key}'
    data = {
        "model": "glm-5.2",  # Model parameter. You can change the model parameter as required.
        "stream":True,
        "messages": [
            {"role": "system", "content": "You are a helpful assistant."},
            {"role": "user", "content": "Hello"}
    response = requests.post(url, headers=headers, data=json.dumps(data), verify=False)
    # Print result.
    print(response.status_code)
    print(response.text)
Run the following commands in the Linux environment:
curl --request POST \
  --url https://api-ap-southeast-1.modelarts-maas.com/anthropic/v1/messages \
  --header 'content-type: application/json' \
  --header 'x-api-key: $MaaS_API_Key' \
  --data '{
  "model": "glm-5.2",
  "stream": true,
  "messages": [
      "role": "system",
      "role": "user",
      "content": "Hello"
Example response:
data: {"type":"message_start","message":{"id":"22cadffad9724d5893e4f9ffed41a695","type":"message","role":"assistant","model":"glm-5.2","content":[],"stop_reason":null,"stop_sequence":null,"usage":{"input_tokens":0,"cache_creation_input_tokens":0,"cache_read_input_tokens":0,"output_tokens":0,"service_tier":"default"}}}
data: {"type":"content_block_start","index":0,"content_block":{"type":"text","text":""}}
data: {"delta":{"type":"text_delta","text":"Hello!"},"type":"content_block_delta","index":0}
data: {"delta":{"type":"text_delta","text":"Is there anything"},"type":"content_block_delta","index":0}
data: {"delta":{"type":"text_delta","text":"I can help"},"type":"content_block_delta","index":0}
data: {"delta":{"type":"text_delta","text":"you with"},"type":"content_block_delta","index":0}
data: {"delta":{"type":"text_delta","text":"?"},"type":"content_block_delta","index":0}
data: {"type":"content_block_stop","index":0}
data: {"type":"message_delta","delta":{"stop_reason":"end_turn","stop_sequence":null},"usage":{"output_tokens":9,"input_tokens":18,"total_tokens":27,"cache_creation_input_tokens":0,"cache_read_input_tokens":0}}
event: message_stop
data: {"type":"message_stop"}
data: [DONE]
Example 2: Tool Calling
Example request:
import requests
import json
    # Send request.
    headers = {
    data = {
        "model": "glm-5.2",
          "thinking": {
            "type": "disabled"
          "stream": False,
          "system": "You are a helpful assistant. Keep replies concise.",
          "messages": [
              "role": "user",
              "content": "What is the weather in Beijing today?"
              "role": "assistant",
              "content": [
                  "type": "tool_use",
                  "id": "call_664e61ca7977429db860d513",
                  "input": {
                    "city": "Beijing",
                    "unit": "celsius"
                  "name": "get_weather"
              "role": "user",
              "content": [
                  "type": "tool_result",
                  "tool_use_id": "call_664e61ca7977429db860d513",
                  "content": "{\"city\": \"Beijing\", \"temperature\": 26, \"unit\": \"celsius\", \"condition\": \"Sunny\"}"
          "tools": [
              "name": "get_weather",
                "description": "Get the current weather for a specified city.",
              "input_schema": {
                "type": "object",
                "properties": {
                  "city": {
                    "type": "string",
                    "description": "City name, for example, Beijing."
                  "unit": {
                    "type": "string",
                    "enum": [
                      "celsius",
                      "fahrenheit"
                    "description": "Temperature unit"
                "required": [
                  "city"
    # Print result.
  --data '{
  "model": "glm-5.2",
  "thinking": {
    "type": "disabled"
  "stream": false,
  "messages": [
      "role": "user",
      "content": [
          "type": "tool_use",
          "input": {
            "city": "Beijing",
            "unit": "celsius"
      "role": "user",
      "content": [
  "tools": [
      "input_schema": {
        "type": "object",
        "properties": {
          "city": {
            "type": "string",
          "unit": {
            "type": "string",
            "enum": [
              "celsius",
              "fahrenheit"
        "required": [
          "city"
Example response:
  "content": [
      "text": "Today's weather in Beijing: **Sunny**, temperature **26°C**. The weather is great for travel! ☀️",
      "type": "text"
  "id": "1d3756ed5704491f980c2fd40054bfd7",
  "model": "glm-5.2",
  "stop_reason": "end_turn",
  "stop_sequence": null,
  "type": "message",
  "usage": {
    "cache_creation_input_tokens": 0,
    "cache_read_input_tokens": 0,
    "input_tokens": 250,
    "output_tokens": 23,
    "service_tier": "default",
    "total_tokens": 273
Example 3: Image Understanding (Multiple Images)
Example request:
import requests
import json
import base64
#  Base64-encode the image.
def encode_image(image_path):
    with open(image_path, "rb") as image_file:
        return base64.b64encode(image_file.read()).decode("utf-8")
base64_image = encode_image("test.png") # Replace it with the actual image path.
    # Send request.
    headers = {
    data = {
        "model": "deepseek-v4.1-flash",  # Model parameter
        "messages": [
                "role": "user",
                "content": [
                        "type": "text",
                        "text": "Describe the content in the two images"
                        "type": "image",
                        "source": {
                            "type": "url",
                            "url": "https://example.com/example.png"
                        "type": "image",
                        "source": {
                            "type": "base64",
                            "media_type": "image/png",
                            "data": f"{base64_image}"
    response = requests.post(url, headers=headers, data=json.dumps(data))
    # Print result.
  --url "https://api-ap-southeast-1.modelarts-maas.com/anthropic/v1/messages" \
  --header 'authorization: Bearer $MAAS_API_KEY' \
  --data '{
  "messages": [
            "role": "user",
            "content": [
                    "type": "text",
                    "type": "image",
                    "source": {
                        "type": "url",
                    "type": "image",
                    "source": {
                        "type": "base64",
                        "data": "$BASE64_IMAGE"
