Connecting VPCs to On-Premises Data Centers
If you have an on-premises data center and not all your workloads can be migrated to the cloud, you can use the network services described in Table 1 to connect your on-premises data center to the VPCs.
| Network Service | Function | Highlights |
| VPN provides an encrypted, Internet-based channel that connects an on-premises data center and the cloud. |
| Direct Connect establishes a dedicated network connection between an on-premises data center and the cloud. |
| With VPC Peering, you can peer two VPCs in the same region, no matter whether they are in the same account or different accounts. VPC Peering can work with Direct Connect or VPN to enable your on-premises data center to access multiple VPCs. |
| You can use VPN or Direct Connect to connect an on-premises data center to a VPC, and then use an enterprise router to connect multiple VPCs if there are in the same region. |
| Cloud Connect | You can use Direct Connect or VPN to connect on-premises data centers to VPCs in multiple regions and then use a cloud connection or central network to connect the VPCs, so that the on-premises data centers can access all the VPCs. By working with Direct Connect, Cloud Connect provides the following two options:
Connecting a Single VPC to an On-Premises Data Center
You can use Direct Connect or VPN to connect a VPC to an on-premises data center.
Before connecting a VPC to an on-premises data center, you need to plan their CIDR blocks in advance to ensure that the VPC CIDR block does not overlap with the on-premises CIDR block, or communications may fail.
For details, see Configuring Enterprise Edition S2C VPN to Connect an On-premises Data Center to a VPC.
For details, see Accessing a VPC over a Direct Connect Connection and Using BGP to Route Traffic.
Connecting Multiple VPCs in the Same Region to an On-Premises Data Center
- Ensure that the VPC CIDR blocks do not overlap with the on-premises CIDR block, or communications may fail.
- Ensure that the VPC CIDR blocks do not overlap, or communications may fail.
For details, see Connecting an On-Premises Data Center to Multiple VPCs that Need to Communicate with Each Other.
In Figure 3, some workloads are running in two VPCs (VPC-A and VPC-B) in a region, and some workloads are running in the on-premises data center. The on-premises data center connects to a VPC (VPC-B) over a Direct Connect connection, and VPC-A and VPC-B are connected over a VPC peering connection. In this way, the on-premises data center can access both VPC-A and VPC-B.
- Setting Up a Hybrid Cloud Network Using Enterprise Router and Direct Connect (Global DC Gateway)
- Setting Up a Hybrid Cloud Network Using Enterprise Router and a Pair of Direct Connect Connections (Global DC Gateway)
- Setting Up a Hybrid Cloud Network Using Enterprise Router and a Pair of Active/Standby Direct Connect Connections (Global DC Gateway)
- Setting Up a Hybrid Cloud Network Using Enterprise Router, VPN, and Direct Connect (Global DC Gateway)
In Figure 4, some workloads are running in two VPCs (VPC-A and VPC-B) in a region, and some workloads are running in the on-premises data center. The two VPCs and global DC gateways are attached to an enterprise router in the same region, so that the two VPCs can communicate with each other and also with the on-premises data center.
In this example, two Direct Connect connections are deployed to balance loads, improving the network performance and reliability. When both connections work normally, the network transmission capability is greatly improved. If one connection becomes faulty, the other connection can take over services, and your on-premises data center can still access the VPCs.
Connecting Multiple VPCs in Different Regions to On-Premises Data Centers
To use a cloud connection to connect VPCs in different regions, you also need to load the virtual gateway for each VPC to the cloud connection. In this way, on-premises data centers in multiple cities can access the VPCs.
For details, see Connecting Multiple On-Premises Data Centers to Multiple VPCs in Different Regions.
In Figure 5, there are two on-premises data centers (IDC-A and IDC-B) in different cities, with each connected to a VPC over a Direct Connect connection (DC-A and DC-B). DC-A connects IDC-A in city A to VPC-A in region A, and DC-B connects IDC-B in city B to VPC-B in region B. The two VPCs and virtual gateways are connected over a cloud connection to set up a cross-region private network. In this way, VPC-A, VPC-B, IDC-A and IDC-B can communicate with each other.
You can attach VPCs and Direct Connect global DC gateways in the same region to an enterprise router, and then add the enterprise routers in different regions to a central network. In this way, VPCs in different regions can communicate with on-premises data centers in multiple cities. Compared with a cloud connection, using a central network features a simpler architecture and higher scalability.
