Global Internet Bandwidth Usage Guidelines
Overview
A global internet bandwidth can be shared by one or more global EIPs at the same time, improving bandwidth utilization.
Global internet bandwidths have to work together with global EIPs for Internet access. You can add one or more global EIPs to the same global internet bandwidth. A global EIP and its global internet bandwidth must use the same access point. In Figure 1, global EIP-A, global EIP-B, and global EIP-C are added to global internet bandwidth-A. The global EIPs and the global internet bandwidth use the same access point, that is, CN East-Hangzhou.
Common Operations
