Help Center/
MapReduce Service/
User Guide (Paris Region)/
FusionInsight Manager Operation Guide (Applicable to 3.x)/
Tenant Resources/
Using the Superior Scheduler/
Managing Resources/
Modifying a Resource Pool
Updated on 2024-10-11 GMT+08:00
When hosts in a resource pool need to be adjusted based on service requirements, you can modify members in the resource pool on FusionInsight Manager.
- Choose .
- Locate the row that contains the specified resource pool, and click Edit in the Operation column.
- In the Resource area, modify hosts.
- Adding hosts: Select desired hosts in Available Hosts and click
to add them to the resource pool. - Deleting hosts: Select desired hosts in Selected Hosts and click
to remove them from the resource pool. The host list in the resource pool can be left blank.
- Click OK.
Parent topic: Managing Resources
