On this page
Log Online Search
Updated on 2024-10-11 GMT+08:00
FusionInsight Manager allows you to search for logs online and view the log content of components to locate faults.
  2. Choose O&M > Log > Online Search.
  3. Configure the parameters listed in Table 1 to search for the logs you need. You can select a default log search duration (including 0.5h, 1h, 2h, 6h, 12h, 1d, 1w, and 1m), or click to customize Start Data and End Data.
    Table 1 Log search parameters
    Search Content
    Keywords or regular expression to be searched for
    Service
    Service or module for which you want to query logs
    File
    Log files to be searched for when only one role is selected
    Lowest Log Level
    Lowest level of logs to be queried. After you select a level, the logs of this level and higher levels are displayed.
    The levels in ascending order are as follows:
    TRACE < DEBUG < INFO < WARN < ERROR < FATAL
    Host Scope
    • You can click to select hosts.
    • Enter the host name of the node for which you want to query logs or the IP address of the management plane.
    • Use commas (,) to separate IP addresses, for example, 192.168.10.10,192.168.10.11.
    • Use hyphens (-) to indicate an IP address segment if the IP addresses are consecutive, for example, 192.168.10.[10-20].
    • Use hyphens (-) to indicate an IP address segment if the IP addresses are consecutive, and use commas (,) to separate IP address segments, for example, 192.168.10.[10-20,30-40].
      • If this parameter is not specified, all hosts are selected by default.
      • A maximum of 10 expressions can be entered at a time.
      • A maximum of 2,000 hosts can be matched for all entered expressions at a time.
    Advanced Configurations
    • Max Quantity: maximum number of logs that can be displayed at a time. If the number of queried logs exceeds the value of this parameter, the earliest logs will be ignored. If this parameter is not set, the maximum number of logs that can be displayed at a time is not limited.
    • Timeout Duration: log query timeout duration. This parameter is used to limit the maximum log query time on each node. When the query times out, the query is stopped and the logs that have been searched for are still displayed.
  4. Click Search. Table 2 describes the fields in search results.
    Table 2 Parameters in search results
    Time
    Time when a line of log is generated
    Source Cluster
    Cluster for which the log is generated
    Host Name
    Host name of the node where the log file recording the line of log is located
    Location
    Path of the log file recording the line of log
    Click the location information to go to the online log browsing page. By default, 100 lines of logs before and 100 lines after the line of log are displayed. You can click Load More on the top or bottom of the page to view more logs. Click Download to download the log file to the local PC.
    Line No.
    Line number of a line of log in the log file
    Level
    Level of the line of log
    Log
    Log content
    You can click Stop to forcibly stop the search. You can view the search results in the list.
  5. Click Filter to filter the logs to display on the page. Table 3 lists the fields that you can use to filter logs. After you configure these parameters, click Filter to search for logs meeting the search criteria. You can click Reset to clear the information that you have filled in.
    Table 3 Parameters for filtering logs
    Keywords
    Keywords of the losg to be searched for
    Host Name
    Name of the host to be searched for
    Location
    Path of the log file to be searched for
    Started
    Start time for logs to be searched for
    Completed
    End time for logs to be searched for
    Source Cluster
    Cluster for which logs need to be searched
