Help Center/
Database Security Service/
User Guide (Paris and Amsterdam Regions)/
FAQs/
Agent/
What Do I Do If the Database Audit Agent Is Hibernating?
Updated on 2024-01-12 GMT+08:00
After an agent is added for a database to be audited, the initial status of the agent will be Hibernating, as shown in Figure 1.
To use database audit, you need to install the agent.
Check the agent status after you installed it.
- If the agent status changes to Running after the installation, as shown in Figure 2, it indicates that the agent is running properly.
- If the agent status is still Hibernating after the installation, troubleshoot the problem by following the instructions provided in What Do I Do If the Communication Between the Agent and Database Audit Instance Is Abnormal?
Parent topic: Agent
