- What's New
- Function Overview
- Billing
- Getting Started
User Guide
- Overview
- Enabling and Using Database Audit (by Installing Agents)
- Enabling and Using Database Audit (Without Installing Agents)
- Upgrading the Database Audit Instance Version
- Configuring Audit Rules
- Viewing Audit Results
- Notification Settings Management
- Viewing Monitoring Information
- Backing Up and Restoring Database Audit Logs
Other Operations
- Managing Database Audit Instances
- Viewing the Instance Overview
- Managing Databases and Agents
- Uninstalling an Agent
- Management an Audit Scope
- Viewing Information About SQL Injection Detection
- Managing Risky Operations
- Managing Privacy Data Protection Rules
- Managing Audit Reports
- Managing Backup Audit Logs
- Viewing Operation Logs
- Key Operations Recorded by CTS
- Monitoring
- Shared VPC
- Permission Control
Best Practices
- Auditing a User-built Database on ECS
- Auditing an RDS DB instance (with Agents)
- Auditing an RDS DB Instance (Without Agents)
- Deploying the Database Audit Agent in a Container
- Checking for Slow SQL Statements
- Checking for Data Reduction
- Checking for Dirty Tables
- Configuring Oracle RAC Cluster Audit
- Meeting Database Audit Compliance Requirements
- Configuring Database Audit Instance Rules
- Change History
API Reference
- Before You Start
- Calling APIs
API
- Querying on the Management Side
Audit Instance
- Deleting an Audit Instance
- Creating an Audit Instance in Yearly/Monthly Billing Mode
- Querying Information About an Instance Creation Task
- Querying the Audit Instance List
- Changing a Security Group
- Starting an Audit Instance
- Stopping an Audit Instance
- Restarting an Audit Instance
- Updating Audit Instance Information
- Auditing a Database
- Auditing Agent
- Data Analytics
- Audit Rules
- TMS Tags
- Adding an RDS Database (Deprecated)
- Appendix
Product Consulting
- What Is Database Audit?
- What Are the Differences Between DBSS Database Audit and RDS SQL Audit?
- What Editions Does DBSS Provide?
- What Databases on Huawei Cloud Does DBSS Protect?
- What Databases Does DBSS Support?
- Why Can't I See the Instance that Is Being Created After I Purchased It?
- Will My Services Be Affected If I Do Not Renew DBSS After It Expires?
- Does Database Audit Support On-premises or Non-Huawei Cloud Databases?
- What Are Regions and AZs?
- Does DBSS Support Real-Time Data Masking?
- Can DBSS Audit Databases Across Subnets?
- Is There Any Restriction on the Gateway IP Address of DBSS Audit Instances?
Purchase
- Which Subnet Should I Choose When Purchasing an Instance?
- Why Do I Need to Select a VPC When Buying an Instance?
- How Many Database Audit Instances Can I Purchase in the Same Region?
- What Do I Do If a Message Indicating Insufficient Quota Is Displayed During Instance Purchase?
- How Do I Renew Database Audit?
- How Do I Unsubscribe from DBSS?
Functions
- Can Database Audit Be Used Across AZs?
- Does Database Audit (in Bypass Mode) Affect My Services?
- Is the Database Audit Function Available to Users Other Than the Buyer?
- What Are the Functions of Database Audit?
- Supported Database Types
- What OSs Can I Install the Database Audit Agent On?
- Does Database Audit Support Bidirectional Audit?
- Can I Audit Databases Across Different VPCs?
- Can Applications Using TLS Connections Be Audited?
- How Long Is the Database Audit Data Stored by Default?
- How Soon Can I Receive an Alarm Notification If an Exception Occurs in Database Audit?
- Is the Total Number Of Alarms Every Day the Same as that of Emails?
- Why I Cannot Preview the Database Security Audit Report Online?
- If I Use Middleware at the Service Side, Will It Affect Database Audit?
- Can DBSS Capture SQL Statements Executed by Third-Party Tools?
- Can DBSS Be Deployed Off the Cloud?
- Can I Change the VPC of a DBSS Instance?
- How Do I Interconnect with DBSS Audit Data Storage?
- What Should I Do If an Alarm of Insufficient DBSS Capacity Is Displayed?
Agent
- Which Functions Do the Database Audit Agent Provide?
- On What Windows Versions Can I Install the Agent?
- On What Linux OSs Can I Install the Agent?
- What Is the Process Name of the Database Audit Agent?
- (Linux OS) What Should I Do If I Lack the Permission to Run the Agent Installation Script?
- (Linux OS) Where Are the Logs of the Database Audit Agent Saved?
- When Should I Select an Existing Agent?
- What Do I Do If the Database Audit Agent Is Hibernating?
- How Do I Deploy the Agent If I Have an RDS Database That Connects to Multiple ECSs?
- How Do I Determine Where to Install an Agent?
- How Do I Run a Database Audit Agent?
- How Do I Check the Status of the Database Audit Agent?
- How Do I Download a Database Audit Agent?
- How Do I Uninstall a Database Audit Agent?
- Can I Modify the CPU and Memory Thresholds of the Agent?
- How Do I Install the Agent (in Linux OS)?
- How Do I Install the Agent (in Windows OS)?
- What Do I Do If the Communication Between the Agent and Database Audit Instance Is Abnormal?
- How Many Resources Are Consumed by an Agent When It Runs on a Node?
- What Do I Do If Agent Installation Fails?
- What Do I Do If the Error Message "unsupport this Linux version, please check your Linux version with install document!" Is Displayed During Agent Installation?
Operations
- How Do I Configure Database Audit?
- How Do I Disable SSL for a Database?
- How Do I Set the INSERT Audit Policy for Database Audit?
- How Do I Verify My Database Audit Configuration?
- How Do I Set Database Audit Rules for All Databases?
- How Do I Check the Version of Database Audit?
- How Do I View All Alarms in Database Audit?
- How Do I Audit an RDS Database Accessed through Intranet (by Applications Off the Cloud)?
- How Do I Add an HBase Database and Perform Audit?
Troubleshooting
- Database Audit Is Running Properly But Generates No Audit Records
- Database Audit Is Unavailable
- Alarm Notifications Are Abnormal
- Why I Failed to Access the DBSS Purchase Page?
- What Do I Do If I Audit RDS Psostgres Database but No Audit Result Is Displayed?
- DBSS Automatic Backup Failed and The Failure Code is "Export backup file failed"
Logs
- Can the Operation Logs of Database Audit Be Migrated?
- How Long Are the Operation Logs of Database Audit Saved by Default?
- How Do I Check the Operation Logs of Database Audit?
- How Does Database Audit Process Logs?
- How Do I Back Up the Database Audit Logs?
- Can Database Audit Logs Be Directly Saved to OBS?
- Backup Gets Stuck at the Backup File Uploading Phase
- Change History
Product Consulting
- Videos
More Documents
- Overview
- Process Overview
- Applying for a Database Audit Instance
- Step 1: Add a Database
- Step 2: Add an Agent
- Step 3: Download and Install the Agent
- Step 4: Add a Security Group Rule
- Step 5: Enable Database Audit
- Adding Audit Scope
- Enabling or Disabling SQL Injection Detection
- Adding Risky Operations
- Configuring Privacy Data Protection Rules
- Viewing SQL Statement Details
- Viewing Session Distribution
- Viewing the Audit Dashboard
- Viewing Audit Reports
- Configuring Alarm Notifications
- Viewing the System Monitoring
- Viewing the Alarms
- Viewing Tracing Logs
- Auditable Operations
- Product Consulting
Functions
Agent
- Operations
- Troubleshooting
Logs
- Change History
- Overview
- Quick Start
- Step 3: Add a Security Group Rule
- Step 4: Download and Install the Agent
- Step 6: View Audit Results
Other Operations
Functions
Agent
- Operations
- Troubleshooting
Logs
- Change History
User Guide (Paris and Amsterdam Regions)
- Overview
Functions
Agent
- Operations
- Troubleshooting
- Logs
Functions
- Change History
- API Reference (Paris and Amsterdam Regions)
On this page
Show all
Help Center/
Database Security Service/
User Guide (Paris and Amsterdam Regions)/
FAQs/
Logs/
Database audit logs are stored in a log database and processed based on disk usage.
- If the disk usage of the log database is 85% or higher, the system automatically deletes the audit logs generated on the earliest date until the disk usage drops below 85%.
- If the disk usage is 90% or higher, database audit stops and the system no longer saves new audit logs.
Parent topic: Logs
