Configuring Alarm Notifications
- Alarm notifications may be mistakenly blocked. If you have enabled notifications but not received any, check whether they have been blocked as spasms.
 - The system collects alarm statistics every 5 minutes and sends alarm notifications (if any).
 - You can also enable report notifications to get notified when the reports you subscribed to are generated. For details, see Viewing Audit Reports.
You have applied for a database audit instance and the Status is Running.
 - Select a region, click
, and choose . The Dashboard page is displayed. - In the navigation tree on the left, choose Settings.
 - In the Instance drop-down list, select an instance to configure alarm notifications.
 - Click the Alarm Notifications tab.
 - Set alarm notifications. For details about related parameters, see Table 1.
    Figure 1 Configuring alarm notifications
    Table 1 Alarm notification parameters Parameter
Example Value
Message Notifications
Enables or disables notifications.
SMN Topic
Select an existing topic from the drop-down list or click View Topic and create an SMN topic on the displayed page for configuring the terminals for receiving alarm notifications.
NOTE:Before selecting a topic, ensure that the subscription status of the topic is Confirmed. Otherwise, alarm notifications may not be received.
For details about topics and subscriptions, see Simple Message Notification User Guide.
Daily Alarm Notifications
Total number of alarms allowed to be sent every day
NOTICE:- If the number of alarms exceeds this value on a day, no more notification will be sent on that day.
 - There is no fixed time point for sending alarm notifications. The system collects statistics every 5 minutes and sends alarm notifications (if any).
30
Alarm Risk Severity
Risk severity of the risk log. The options are as follows:
- High
 - Moderate
 - Low
High
CPU Alarm Threshold (%)
CPU alarm threshold of an audit instance. When the threshold is exceeded, an alarm notification is generated.
80
Memory Alarm Threshold (%)
Memory alarm threshold of an audit instance. When the threshold is exceeded, an alarm notification is generated.
80
Disk Alarm Threshold (%)
Disk alarm threshold of an audit instance. When the threshold is exceeded, an alarm notification is generated.
80
 - Click Apply.
