Managing Audit Reports
By default, database audit complies with a full audit rule, which is used to audit all databases that are successfully connected to the database audit instance. After connecting the database to the database audit instance, view report templates and report results.
- You have applied for a database audit instance and the Status is Running.
- Database audit has been enabled.
- Audit reports have been generated.
Viewing a Report
- Select a region, click
, and choose . The Dashboard page is displayed. - In the navigation tree on the left, choose .
- In the Instance drop-down list, select the instance whose report information you want to view.
- Viewing reports
Figure 1 Viewing a report
- Enter a report name in the upper right corner to search.
- A real-time report is automatically generated in PDF format.
- Locate the row that contains the report to be deleted, click Delete in the Operation column, and click OK in the displayed dialog box. When a report is deleted, you need to manually generate a report if you want to view the report result.
Viewing a Report Template
- In the Instance drop-down list, select the instance whose report template you want to view.
- Click the Report Management tab.
- View the report template information, as shown in Figure 2.
- Report types include Compliance report, Overview report, Database report, Client report, and Database operation report.
- You can enable or disable scheduled tasks, or set their frequency to daily, weekly, or monthly.
- To modify the scheduled task of a report template, click Schedule Task in the Operation column. Modify and save the settings, click Generate Report, and you can check the reports.
