On this page
Adding Risky Operations
Updated on 2024-01-12 GMT+08:00
After enabling database audit, add and configure risky operations for audit.
NOTICE:
One piece of audited data can match only one risky operation rule.
  • You have applied for a database audit instance and the Status is Running.
  • Database audit has been enabled.
  2. Select a region, click , and choose Security > Database Security Service. The Dashboard page is displayed.
  3. In the navigation tree, choose Rules.
  4. In the Instance drop-down list, select an instance to add risky operations. Click the Risky Operations tab. Click Add above the risky operation list.
  5. On the Add Risky Operation page, set the basic information and client IP address, as shown in Figure 1. .
    Figure 1 Setting the basic information and client IP address
    Table 1 Parameters
    Example Value
    Name
    Custom name of a risky operation
    test
    Risk Severity
    Severity of a risky operation. The options are as follows:
    • High
    • Moderate
    • Low
    • No risks
    High
    Status
    Status of a risky operation
    Select Database
    Database that the risky operation will be applied to
    You can select ALL or a specific database.
    Client IP Address or IP Range
    IP address or IP address range of the client
    The IP address can be an IPv4 address (for example, 192.168.1.1) or an IPv6 address (for example, fe80:0000:0000:0000:0000:0000:0000:0000).
    192.168.0.0
  6. Set the operation type, operation object, and execution result, as shown in Figure 2. For details about related parameters, see Table 2.
    Figure 2 Setting the operation type, operation object, and execution result
    Table 2 Parameters
    Example Value
    Operations
    Type of a risky operation, including Login and Operation
    When you select the Operation check box, you can select All operations or the operations in DDL, DML, and DCL.
    Operation
    Objects
    Enter the schema, target table, and field information after clicking Add Operation Object. Click OK to add an operation object.
    Results
    Set Affected Rows and Operation Duration. The operation conditions are as follows:
    • Greater than
    • Less than
    • Equal To
    • Equal to or greater than
    • Less than or equal to
  7. Click Save.
