(Optional) Testing a Domain Name
Test your domain name before adding a CNAME record to the domain's DNS records to ensure that your domain configurations are correct.
- Ping the CNAME for the domain name you added to obtain the IP address.
Example: If the domain name is www.example.com and the generated CNAME address is www.example.com.9c****e7.c.cdnhwc1.com, you can ping www.example.com.9c****e7.c.cdnhwc1.com to get the IP address 10.0.0.0.
- Edit the hosts file on the local PC. If you use a Windows system, map the domain name www.example.com to the IP address 10.0.0.0 in the hosts file in the C:\Windows\System32\drivers\etc\ directory.Figure 1 Testing the domain name
- Access your domain name to test services. If the test results meet your expectation, the configurations are correct.
- Add a CNAME record to your domain's DNS records. For details, see Configuring a CNAME Record.
