Help Center/ Content Delivery Network/ Drawer/ (Optional) Recommended Configurations
Updated on 2025-12-29 GMT+08:00
After adding an acceleration domain name, configure cache rules, smart compression, and secure acceleration to improve the cache hit ratio, optimize the acceleration effect, and enhance security.
Improving Cache Hit Ratio and Optimizing the Acceleration Effect
Configuration Item
The cache hit ratio is low and the acceleration effect is not obvious.
Cache Rules
Set a proper cache TTL and priority for different resources to improve the cache hit ratio, reduce the origin pull ratio, and relieve the pressure on the origin server.
Notes:
  1. The cache rule priority is an integer ranging from 1 to 1,000. A greater number indicates a higher priority.
  2. If you modify or add a cache rule, purge the cache of the corresponding resource.
  3. Set the cache TTL of dynamic resources to 0, so dynamic resources are not cached. Otherwise, access exceptions may occur.
Smart Compression
Compress static content on your websites to reduce the file size, speed up file transfer, and save bandwidth.
  • Smart compression includes gzip compression and Brotli compression. The performance of Brotli compression is 15% to 25% higher than that of gzip compression.
  • With smart compression, CDN automatically compresses .js, .html, .css, .xml, .json, .shtml and .htm files.
URL Parameters
Ignore URL parameters to improve the cache hit ratio and speed up content distribution.
  • If resources do not change with URL parameters, ignore the URL parameters.
  • If resources change with URL parameters, retain the URL parameters.
Improving Access Performance
Configuration Item
Improving origin pull efficiency and reducing pull consumption
Range Requests
Configure range requests to accelerate distribution of large files during origin pull and reduce bandwidth consumption.
  • Range requests are enabled by default for download acceleration.
  • The origin server must support the Range header.
Redirection enabled for origin server resources
Redirect from Origin
If 301 or 302 redirection is configured for the origin server address, the origin server returns status code 301 or 302 to CDN for a pull request. If this function is enabled on CDN, CDN PoPs will redirect to the address specified in the 301 or 302 response to obtain the resource, cache the resource, and return the resource to the user.
Improving Website Security
Configuration Item
Improving security performance
HTTPS
Configure a Secure Sockets Layer (SSL) certificate to improve the domain name security.
Access Control
Identify and filter visitors to restrict their access and improve CDN resource security.
Accelerating Delivery of Resources Protected by WAF
Huawei Cloud CDN works with WAF to defend against web attacks during content delivery acceleration, providing a more secure acceleration experience.
Reducing the Risk of High Bills
Configuration Item
If your domain name is attacked or has malicious traffic coming, there may be sudden traffic spikes that result in a bill higher than your normal expenditures. CDN can help you reduce the risk of high bills.
Usage Cap
Set a usage cap so CDN will disable your domain name when the access bandwidth reaches the threshold you specify to avoid excessive fees.
