Help Center/ Partner Center/ Drawer/ Products That Support 95 Percentile Bandwidth Billing
Updated on 2025-10-24 GMT+08:00
The 95th Percentile Bandwidth is a billing mode for Huawei Cloud CDN and Live services based on bandwidth usage. This billing mode can help you save money during peak bandwidth demands, while ensuring unwavering service reliability and optimal performance.
  • You are billed on a monthly basis. The usage for each month will be billed in the following month.
  • In each calendar month, the peak bandwidth is measured and recorded on each valid day. At the end of the month, the records are sorted from the highest to the lowest, and the top 5% of the records are thrown away. Then the highest bandwidth value in the remaining records is the billable bandwidth of the month.
The following products support 95 Percentile Bandwidth Billing.
