Help Center/
MapReduce Service/
Component Operation Guide (LTS)/
Using Hive/
Hive Enterprise-class Enhancement
- Hive Partitioned Tables Support OBS and HDFS Storage Sources
- Writing a Directory into Hive with the Old Data Removed to the Recycle Bin
- Inserting Data to a Directory That Does Not Exist
- Disabling of Specifying the location Keyword When Creating an Internal Hive Table
- Enabling the Function of Creating a Foreign Table in a Directory That Can Only Be Read
- Configuring HTTPS/HTTP-based REST APIs
- Enabling or Disabling the Transform Function
- Switching the Hive Execution Engine to Tez
- Hive Task Load Balancing
- Access Control of a Dynamic Table View on Hive
- Specifying Whether the ADMIN Permissions Is Required for Creating Temporary Functions
- Viewing Table Structures Using the show create Statement as Users with the select Permission
- Creating Databases and Creating Tables in the Default Database Only as the Hive Administrator
- Authorizing Over 32 Roles in Hive
- Creating User-Defined Hive Functions
- Enhancing beeline Reliability
Parent topic: Using Hive
