- What's New
- Getting Started
- User Guide
- What Is DCC?
- How Is a DCC Billed?
- What Steps Will Be Taken by Huawei Cloud to Handle a Server Fault in a DCC?
- How Do I Select a Region?
- How Is the Memory Allocation Rate in a DCC Computing Resource Pool Calculated?
- FAQs About ECSs
- What Are the Characteristics of ECSs in a DeC?
- How Is an ECS in a DeC Billed?
- API Reference
- Glossary
- More Documents
On this page
Show all
What Is DeC?
Dedicated Cloud (DeC) provides isolated virtual resource pools on the public cloud.
In a DeC, you can exclusively use physical devices, compute and networking resources, and reliable distributed storage.
A DeC is provisioned for you after you have applied for it. You can manage your DeC resources on the management console, as if it was your own private cloud.
Parent topic: Overview
