Functions
- Physical isolation
You can exclusively use computing resources in a DeC. ECSs are created in DeCs that are physically isolated from each other.
 - Network isolation
Network is logically isolated by using Virtual Private Clouds (VPCs). DeC provides customized network segments for DeC users to configure their networks. Pre-configured security policies are provided, so you can build up a multi-dimensional security protection network with ease.
 - Distributed storage
A distributed storage system is used to store instance data.
 - Resource management
You can view the total capacity and consumption of computing resources in a DeC and apply for resources as required.
