Configuring QoS for a Pod
Bandwidth preemption occurs between different containers deployed on the same node, which may cause service jitter. You can configure bandwidth limitation for the pod to solve this problem.
Specifications
Specifications |
Tunnel |
VPC |
Cloud Native Network 2.0 |
Supported cluster versions |
All versions |
Clusters of v1.19.10 and later |
Egress bandwidth limitation |
Supported |
Supported |
Supported |
Ingress bandwidth limitation |
Supported |
Supported |
Supported |
Scenarios where bandwidth limitation is not supported |
None |
None |
Bandwidth limitation range |
Only the rate limit in the unit of Mbit/s or Gbit/s is supported, for example, 100 Mbit/s and 1 Gbit/s. The minimum value is 1 Mbit/s and the maximum value is 4.29 Gbit/s. |
- Pod bandwidth limitation applies to regular containers (runC as the container runtime), not secure containers (Kata Containers as the container runtime).
- Pod bandwidth limitation does not apply to hostNetwork pods.
Using the CCE Console
When creating a workload on the console, you can set pod ingress and egress bandwidth limits by clicking Network Configuration in the Advanced Settings area.
Using kubectl
apiVersion: apps/v1 kind: Deployment metadata: name: test namespace: default labels: app: test spec: replicas: 2 selector: matchLabels: app: test template: metadata: labels: app: test annotations: kubernetes.io/ingress-bandwidth: 100M kubernetes.io/egress-bandwidth: 100M spec: containers: - name: container-1 image: nginx:alpine imagePullPolicy: IfNotPresent imagePullSecrets: - name: default-secret
- kubernetes.io/ingress-bandwidth: ingress bandwidth of the pod
- kubernetes.io/egress-bandwidth: egress bandwidth of the pod
If these two parameters are not specified, the bandwidth is not limited.
After modifying the ingress or egress bandwidth limit of a pod, restart the container for the modification to take effect. After annotations are modified in a pod not managed by workloads, the container will not be restarted, so the bandwidth limits do not take effect. You can create a pod again or manually restart the container.
