Configuring Resource Quotas
Kubernetes provides namespaces for you to group resources in a cluster. Namespaces serve different purposes to meet the needs of multiple users, environments, and applications. To prevent resource abuse and ensure cluster reliability, you can configure quotas for resources like CPUs, memory, and pods for each namespace. For details, see Resource Quotas.
In clusters of v1.21 or later, the default resource quotas will be created when a namespace is created if you have enabled enable-resource-quota in Cluster Configuration Management. Table 1 lists the resource quotas based on cluster specifications. You can modify them according to your service requirements.
Cluster Scale |
Pod |
Deployment |
Secret |
ConfigMap |
Service |
50 nodes |
2000 |
1000 |
1000 |
1000 |
1000 |
200 nodes |
2000 |
1000 |
1000 |
1000 |
1000 |
1000 nodes |
5000 |
2000 |
2000 |
2000 |
2000 |
2000 nodes |
5000 |
2000 |
2000 |
2000 |
2000 |
- In the navigation pane, click Namespaces.
- Click Quota Management next to the target namespace.
This operation cannot be performed on system namespaces kube-system and kube-public.
- Configure the resource quotas and click OK.
- After configuring CPU and memory quotas for a namespace, you must specify the request and limit values of CPU and memory resources when creating a workload. Otherwise, the workload cannot be created. If the quota of a resource is set to 0, the resource usage is not limited.
- Accumulated quota usage includes the resources used by CCE to create default components, such as the Kubernetes Services (which can be viewed using kubectl) created under the default namespace. Therefore, you are advised to set a resource quota greater than expected to reserve resource for creating default components.
- Kubernetes provides optimistic concurrency control (OCC), also known as optimistic locking, for frequent data updates. You can use optimistic locking by defining the resourceVersion field. This field is in the object metadata. This field identifies the internal version number of the object. When the object is modified, this field is modified accordingly. You can use kube-apiserver to check whether an object has been modified. When the API server receives an update request containing the resourceVersion field, the server compares the requested data with the resource version number of the server. If they are different, the object on the server has been modified when the update is submitted. In this case, the API server returns a conflict error (409). Obtain the server data, modify the data, and submit the data to the server again. Resource quotas limit the total resource usage of each namespace and maintain a record of resource information in the cluster. Enabling resource quotas may result in more resource creation conflicts in high-concurrency scenarios, which can affect the performance of batch resource creation.
