RDS.Volume
Property Description
        Property  |
        Mandatory  |
        Type  |
        Description  |
        volumetype  |
        Yes  |
        Cloud.RDS.Volume.Type.Name  |
        Disk type Value Description: The options are COMMON (SATA), HIGH (SAS), and ULTRAHIGH (SSD). These values are case sensitive. Value Constraint: Set the value based on requirements. Suggestion: Set the value based on specifications.  |
        size  |
        Yes  |
        integer  |
        Disk size Value Description: The value ranges from 40 to 4000. Unit: GB. Value Constraint: The value ranges from 40 to 4000. The value must be an integer multiple of 10. Suggestion: Set the value based on specifications.  |
