On this page
CCE.NodePool
Property Description
Table 1 Property description
Property
Mandatory
Type
dataVolumes
Yes
CCE.DataVolume
Data disk of the created node
Value Description: Customize the value, for example, [{"volumeType":"SATA","size":100}].
Value Constraint: Array format. Currently, only one object is supported.
Suggestion: Customize the value.
availabilityZone
Yes
Cloud.ECS.AvailabilityZone.Name
AZ where the node is located
Value Description: AZ where the to-be-created ECS is located. The name of the AZ needs to be specified, for example, ae-ad-1a. For details, see the Regions and Endpoints page.
Value Constraint: Select a value based on the region.
Suggestion: Use the get_input function to set this field, and then the value can be automatically selected on the AOS console.
name
No
string
Name of the created node
Value Description: Customize the value.
Value Constraint: The value contains 4 to 32 characters and must start with a lowercase letter. Only lowercase letters, digits, and underscores (_) are allowed.
Suggestion: Customize the value. Generally, the stack name is used as the node name.
publicKey
No
Cloud.ECS.KeyPair.PublicKey
Public key of the key pair when the stack is billed in the yearly/monthly mode
Value Description: Selects an existing public key.
Suggestion: Use the get_input function to set this field, and then the value can be automatically selected on the AOS console based on the value of sshKeyName.
postInstall
No
string
Node post-installation script
Value Constraint: The script you specify here will be executed after K8S software is installed
Suggestion: The script is usually used to modify Docker parameters.
labels
No
dict
labels of the created node
Value Description: Customize the value, for example, {"key": "aos","value": "app","scope":[1,2]}.
Suggestion: Enter the key, value, and scope as required.
preInstall
No
string
Node pre-installation script
Value Constraint: The script you specify here will be executed before K8S software is installed. Note that if the script is incorrect, K8S software may not be installed successfully.
Suggestion: The script is usually used to format data disks.
publicIp
No
CCE.PublicIP
Virtual IP address of the created node
Value Description: Customize the value, for example, {"eip":{"bandwidth:{" shareType":PER}, 5_sbgp"}}.
Value Constraint: Only one elastic IP address can be defined for each node.
instances
Yes
integer
Number of created nodes
Value Description: Customize the value. The value ranges from 1 to 50.
Value Constraint: {u'in_range': [1, 50]}
Suggestion: Set the value based on specifications and requirements.
rootVolume
Yes
ECS.RootVolume
System disk of the created node
Value Description: Customize the value, for example, {"volumeType":"SATA","size":40}.
os
No
string
os of the created node
Value Description: ["EulerOS 2.2", "CentOS 7.4"]
Value Constraint: Customize the value. If this parameter is left blank, EulerOS 2.2 is used by default.
Suggestion: The options are EulerOS 2.2 and CentOS 7.4.
nodePasswd
No
password
Password of the node root user
Value Constraint: 1. The parameter must be written into inputs and set using the get_input function. 2. The value must not be left blank or is a weak password. Enter 8 to 26 characters. Only uppercase and lowercase letters, digits, and special characters !@$%^-_=+[{}]:,./? are allowed. The value must contain at least two types of characters. 3. sshkeyName and nodePasswd cannot be used at the same time.
Suggestion: You are advised to use the get_input function to obtain the value and avoid plaintext passwords to ensure security.
flavor
Yes
Cloud.CCE.Node.Flavor.Name
Container node specification
Value Description: ID of the system flavor of the ECS to be created. You are advised to set this parameter in get_input mode.
Suggestion: Select the node specification during node creation on the CCE console. In the node template, you can set the inputs to specify the node specification.
sshKeyName
Yes
Cloud.ECS.KeyPair.Name
Key pair used for logging in to a node, which needs to be kept properly
Value Description: It must be created on the ECS console in advance.
Value Constraint: sshkeyName and nodePasswd cannot be used at the same time.
Suggestion: 1. You are advised to use the get_input function to assign values so that you can select a value when using the template. 2. Obtain the information on the ECS console and then enter the information accordingly.
annotations
No
dict
Annotations of Node
Value Description: Customize the value, for example, {"app": "aos"}.
Suggestion: You can enter multiple key-value pairs.
