CCE.Labels
Property Description
        Property  |
        Mandatory  |
        Type  |
        Description  |
        scope  |
        No  |
        integer  |
        Number of the nodes labeled Value Description: Enter an integer that is not greater than the number of nodes. If the value is obtained through the get_input function, set its type to integer, for example, type: integer. Suggestion: Customize the value.  |
        key  |
        No  |
        string  |
        Key of the label Value Description: Customize the value. Suggestion: Customize the value.  |
        value  |
        No  |
        string  |
        Value of the label Value Description: Customize the value. Suggestion: Customize the value.  |
